Device Compatibility: Sensirion Parallax sensor
Results 1 to 5 of 5
    embdfreak's Avatar
    embdfreak Guest
    Default Device Compatibility: Sensirion Parallax sensor
    Hi all,
    Im new to this forum and dont have much experience with PBP. Im working on a Sensirion SHT11 Parallax Sensor for temperature/Humidity acq. The problem is, the code gives perfect results when ran on PIC16f84a but gives weird readings if same code is run on a PIC16f877a.
    Following is the code. Please give suggestion to get over this problem.
    Ive modified the code actually presented with the Application note.
    INCLUDE "modedefs.bas"
    ' I/O Definitions
    ShtData VAR PORTd.0
    Clock VAR PORTd.1
    ' Constants
    ShtTemp CON %00011 ' read temperature
    ShtHumi CON %00101 ' read humidity
    ShtStatW CON %00110 ' status register write
    ShtStatR CON %00111 ' status register read
    ShtReset CON %11110 ' soft reset (wait 11 ms after)
    Ack CON 0
    NoAck CON 1
    No CON 0
    Yes CON 1
    MoveTo CON 2 ' for DEBUG control
    ClrRt CON 11 ' clear DEBUG line to right
    DegSym CON 186 ' degrees symbol for DEBUG
    ' Variables
    ioByte VAR Byte ' data from/to SHT1x
    ackBit VAR Bit ' ack/nak from/to SHT1x
    toDelay VAR Byte ' timeout delay timer
    timeOut VAR Bit ' timeout status
    soT VAR Word ' temp counts from SHT1x
    tC VAR Word ' temp - celcius
    tF VAR Word ' temp - fahrenheit
    soRH VAR Word ' humidity counts from SHT1x
    rhLin VAR Word ' humidity; linearized
    rhTrue VAR Word ' humidity; temp compensated
    PWMvalue VAR WORD
    ' -------------------------------------------------------------------------'Initialization
    Initialize:
    GOSUB SHT_Connection_Reset ' reset device connection
    PAUSE 250 ' let DEBUG window open
    GOTO Main ' skip heater demo
    ' Program Code
    SEROUT2 PORTA.0,16572,["SHT11 DEMO",13,10] ' 16572 = value for 4800bps
    Main2:
    GOSUB SHT_Measure_Temp
    SEROUT2 PORTA.0,16572,["Temp(C)=",DEC tc/10,".",DEC tC//10," "]
    GOSUB SHT_Measure_Humidity
    SEROUT2 PORTA.0,16572,["Hum(Lin)=",DEC rhLin/10,"%"," "]
    rhTrue=rhTrue/10
    SEROUT2 PORTA.0,16572,["Hum(True)=",DEC rhTrue,"%",10,13]
    GOTO Main2
    ' Subroutines
    ' connection reset: 9 clock cyles with ShtData high, then start sequence
    SHT_Connection_Reset:
    SHIFTOUT ShtData, Clock, LSBFirst, [$FFF\9]
    ' generates SHT1x "start" sequence
    ' _____ _____
    ' ShtData |_______|
    ' ___ ___
    ' Clock ___| |___| |___
    SHT_Start:
    INPUT ShtData ' let pull-up take line high
    LOW Clock
    HIGH Clock
    LOW ShtData
    LOW Clock
    HIGH Clock
    INPUT ShtData
    LOW Clock
    ' measure temperature
    ' -- celcius = soT * 0.01 - 40
    ' -- fahrenheit = soT * 0.018 - 40
    SHT_Measure_Temp:
    GOSUB SHT_Start ' alert device
    ioByte = ShtTemp ' temperature command
    GOSUB SHT_Write_Byte ' send command
    GOSUB SHT_Wait ' wait until measurement done
    ackBit = Ack ' another read follows
    GOSUB SHT_Read_Byte ' get MSB
    soT.HighByte = ioByte
    ackBit = NoAck ' last read
    GOSUB SHT_Read_Byte ' get LSB
    soT.LowByte = ioByte
    ' Note: Conversion factors are multiplied by 10 to return the
    ' temperature values in tenths of degrees
    tC = soT / 10 - 400 ' convert to tenths C
    SEROUT2 PORTA.0,16572,["Temp Form(C)=",DEC tc,10,13]
    tC = soT **$1999 - 400
    ' measure humidity
    SHT_Measure_Humidity:
    ioByte = ShtHumi ' humidity command
    soRH.HighByte = ioByte
    soRH.LowByte = ioByte
    rhLin= (soRH ** $67AE) - (soRH ** $83 * soRH ** $5B) - 40
    rhTrue = (tC-250) * (soRH ** $34) + rhLin
    ' sends "ioByte"
    ' returns "ackBit"
    SHT_Write_Byte:
    SHIFTOUT ShtData, Clock, MSBFirst, [ioByte] ' send byte
    SHIFTIN ShtData, Clock, LSBPre, [ackBit\1] ' get ack bit
    ' returns "ioByte"
    ' sends "ackBit"
    SHT_Read_Byte:
    SHIFTIN ShtData, Clock, MSBPre, [ioByte] ' get byte
    SHIFTOUT ShtData, Clock, LSBFirst, [ackBit\1] ' send ack bit
    INPUT ShtData ' release data line
    SHT_Wait:
    INPUT Shtdata
    timeout = NO
    For toDelay = 1 TO 250
    if (ShtData = 0) THEN RETURN
    PAUSE 1
    NEXT
    IF ( toDelay = 250 ) THEN timeout = Yes
    Wink Rtfm ....
    Hi, freak
    You just have to configure the extra registers in your 16F87x ... i.e. choose for digital inputs instead of analog, etc. etc.
    Everything in the chip Databook.
    embdfreak's Avatar
    embdfreak Guest
    well, i dont see anything like analog being used here. or rather i havent understood your answer properly. Can u please explain a bit further on. I truly dont know what to set cuz i have only two lines (data & clock ) to communicate with the sensor and nothing analog. plz have a look at the code and reply
    Feb 2005
    Kolkata-India
    Default By default the inputs are Analogue
    PICs which feature ADC have multiplexed inputs. That is either they go to the ADC or the digital I/O. By default (POR) the inputs are analogue. There are registers to set this according to your app. For your PIC it is the ADCON1
    ADCON1 = %xxxx0110 ' where the x is your own setting turns of the ADC inputs and configures all as Digital I/O.
    Read page 129-130 of your datasheet.
    Sougata
    Hi, SOUGATA
    My inputs work well ... ( set to 7F ... as datasheet tells )
    only the EEPROM is running bad.
  1. Need a cheap touch sensor idea.. here it is
    By mister_e in forum Code Examples
    Last Post: - 16th April 2016, 22:42
  2. Watchdog Timers
    By Squibcakes in forum mel PIC BASIC Pro
    Last Post: - 27th August 2014, 18:03
  3. RF Modules
    By tonyfelloni in forum mel PIC BASIC Pro
    Last Post: - 26th June 2010, 17:42
  4. Sensirion humidity sensor
    Last Post: - 7th October 2008, 15:48
  5. @ Device Parameters
    By Randy_Suwanee in forum General
    Last Post: - 11th August 2004, 14:40
