Bi-Direction serial communication PC > PIC *16F84A via RWS-434 TWS-434
Results 1 to 12 of 12
    Jul 2005
    Exclamation Bi-Direction serial communication PC > PIC *16F84A via RWS-434 TWS-434
    I've been trying to obtain rf wireless communication to my pic projects for awhile now... recently I managed to get my pc's serial port to transmit out a TWS transmitter module to the RWS reciever at N2400 baud (yay) i can "trigger" my reciever address "if" statement and get to the underlying functions (i'm hoping these parts of the program can talk to the other pic's and update variables on those which in turn provide the desired functionality. This is a rc robot/car
    the recadd byte is next byte out after the "254" qualifier
    I then have a variable "bitvalue" ' basically the 0-255 I would like to send to the different PIC's which control various features (motor direction, HPWM motor speed control, various lights, possibly a rototating "platter" for my camera to sit on)
    but enough about the PC > PIC transmission... my problem is the opposite, the PIC > PC transmission and recipt.
    The problem is my vb program gets garbled data
    it looks like this: ûo—ÿû[¸
    qH
    maybe somebody could post a schematic for connecting both a RWS /TWS to both pic and pc so i know i have my connections right. (especially resistor values)
    Jul 2005
    Default Rws-434 Tws-434a Serin/serout Update
    I thought i'd update my post with more information as i am still unable to resolve my receiver difficulties and really require some intervention.
    My PC side is like this for hardware:
    PC SERIAL PORT TX > PIN2 TWS TRANSMITTER MODULE (works) Sends output of serial port from Visual Basic program using Com 1 2400,n,8,1
    PC SERIAL PORT GND > GND
    PC SERIAL PORT RX < RWS-434 Data out (have tried both pin 2 "Digital" output, tried pin 3 "Linear" output with 47k resistor to ground, "Linear" is what is used successfully on the remote pic side.) doesnt work or strange charecters received.
    The Pic side looks like this:
    pin 1 (PortA.2 "serpin" in my pic's software program) to RWS-434 modules "Linear" data output with 47k resistor to ground. (Works) Pic receives data qualifier and procceds through program as expected. The pic side RWS-434 has pin 1 > GND, pin 2 > SOMETIMES TO SERIAL PORT RX, pin 3 > SOMETIMES TO SERIAL PORT RX , pin 4 > VCC +5 (4.9), pin 5 > VCC +5 , pin 6 > GND , pin 7 > GND , pin 8 > ANT.
    pin 2 (PortA.3 "serpout" in my pic's software program) to TWS-434A "data in" pin 2.
    The 4 antennas (I'd eventually like to use just the 1 on each side) have been swapped in one at a time to the working PC > PIC TWS > RWS part of the circuit so they can likely be ruled out as the problem.
    The project is currently breadboarded (3 breadboards actually) with the PC side device (meaning the TWS+RWS+7805C) on a smaller breadboard.
    The pic side layout currently is having the Pic and teh tws on a small breadboard with the working RWS on its own breadboard. ( I scrapped a couple of working TX > RX TWS / RWS w/ holtek encoders that i had going to start development immediately of the serial RF modem type communication)
    The PIC program is as follows: (sorry for the mamoth post but i thought it be good to post the complete picture)
    More of my questions and comments after the code:
    (my post is too long i'll re-post my code)
    As you can see i'm hoping to eventually Parse the returned data.
    But first to get the data over RF from the pic side.
    Any ideas on what is my problem... maybe we could move this post to a more appropriate section... i didnt realize i was in the PIC wishlist (oops, sorry)
    Jul 2005
    Default code
    '* Name : SERIAL RF *
    '* Author : Ryan Barrett *
    '* Notice : Copyright (c) 2005 Rytech Computing *
    '* : All Rights Reserved *
    '* Date : NOV 2005 *
    '* Version : 1.0 *
    '* Notes : *
    '* : PC to PIC and vice-versa! *
    INCLUDE "bs2defs.bas"
    RECADD VAR b3 '8 bit latch number
    BITVALUE VAR byte '8 bit latch value
    MCONTROL1 var b5 'MOTORCONTROL BYTE - FORWARD BACK LEFT RIGHT
    MSPEED1 var b6 'MOTORSPEED BYTE FOR HPWM
    LIGHTS1 var b7 'BYTE CONTROLLING LED LIGHTS
    LVAL4 var b8
    'CVAL1 var b9
    'CVAL2 var b10
    'CVAL3 VAR b11
    'CVAL4 VAR b12
    'i var byte
    serpin VAR porta.2 'serial input pin
    serpout var porta.3 'serial output pin
    INITIAL:
    trisa = %00000100
    'trisa = %00010000
    trisb = %00000000
    MCONTROL1 = 0
    MSPEED1 = 0
    LIGHTS1 = 0
    LVAL4 = 0
    PORTB = 0
    'flash leD
    HIGH portA.1
    PAUSE 700
    LOW portA.1
    PAUSE 800
    'flash leD
    HIGH portA.1
    PAUSE 1000
    LOW portA.1
    PAUSE 800
    'flash leD
    HIGH portA.1
    PAUSE 1000
    LOW portA.1
    PAUSE 800
    HIGH portA.1
    PAUSE 1000
    LOW portA.1
    GoTO loop
    loop:
    BITVALUE = 0
    SERIN serpin,N2400,[254],RECADD,BITVALUE' serial data in on portA.1
    serout serpout,N2400,[220,#MCONTROL1]
    IF RECADD = 1 THEN outr1 ' if request is for RECADD#1 then goto RECADD#1 routine
    IF RECADD = 2 THEN outr2 ' if request is for RECADD#2 then goto RECADD#2 routine
    IF RECADD = 3 THEN outr3 ' if request is for RECADD#3 then goto RECADD#3 routine
    IF RECADD = 4 THEN outr4 ' if request is for RECADD#4 then goto RECADD#4 routine
    IF RECADD = 5 THEN outr5 ' if request is for RECADD#5 then goto RECADD#5 routine
    IF RECADD = 6 THEN outr6 ' if request is for RECADD#6 then goto RECADD#6 routine
    GOTO loop
    outr1:
    HIGH portA.1
    Pause 1000
    MCONTROL1 = BITVALUE
    'INSERT OUT SERIAL TO OTHER PIC CONTROLLING MOTOR DIRECTIONS
    LOW portA.1: GOTO loop
    outr2:
    HIGH portA.1
    Pause 1000
    MSPEED1 = BITVALUE
    'INSERT OUT SERIAL TO OTHER PIC CONTROLLING MOTOR HPWM
    outr3:
    HIGH portA.1
    Pause 1000
    LIGHTS1 = BITVALUE
    'INSERT OUT SERIAL TO LED PIC CONTROLLING LEDS
    outr4:
    HIGH portA.1
    Pause 1000
    LVAL4 = BITVALUE
    GOTO loop
    outr5:
    HIGH portA.1
    PAUSE 1000
    LOW portA.1
    Pause 1000
    HIGH portA.1
    Pause 1000
    LOW portA.1
    Pause 1000
    HIGH portA.1
    Pause 1000
    LOW portA.1
    Pause 1000
    HIGH portA.1
    Pause 1000
    LOW portA.1
    Pause 1000
    HIGH portA.1
    Pause 1000
    LOW portA.1
    Pause 1000
    HIGH portA.1
    Pause 1000
    outr6:
    HIGH portA.1
    Pause 700
    LOW portA.1
    Pause 700
    HIGH portA.1
    Pause 700
    LOW portA.1
    Pause 700
    HIGH portA.1
    Pause 700
    LOW portA.1
    Pause 700
    HIGH portA.1
    Pause 700
    LOW portA.1
    Pause 700
    HIGH portA.1
    Pause 700
    LOW portA.1
    Pause 700
    HIGH portA.1
    Pause 700
    LOW portA.1
    Pause 700
    HIGH portA.1
    Pause 700
    GOTO loop
    The Visual Basic Program is very immature and looks something like this:
    ' PC > PIC SERIAL RF
    ' Ryan Barrett
    ' Rytech Computing
    ' DEC 2005
    Private Declare Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As Long)
    Public bit1value As Integer
    Public bit2value As Integer
    Public bit3value As Integer
    Public bit4value As Integer
    Public allbitout As Integer
    Public allbitout8 As Integer
    Public recadd As Integer
    Dim oldlogtext As String
    Dim serinput As String
    Private Sub AddressList_Click()
    recadd = AddressList.ItemData(AddressList.Text)
    'MsgBox (recadd)
    'Call TransmitIt
    End Sub
    Private Function TransmitIt2()
    'For I = 1 To 3 ' Loop 4 times
    MSComm1.Output = Chr$(254) & Chr$(recadd) & Chr$(allbitout8)
    'Pause 235 ' Pause 250mS
    oldlogtext = SERIALINLOG.Text
    serinput = MSComm1.Input
    SERIALINLOG.Text = "Incoming Data: " + serinput + vbCrLf + oldlogtext
    'PARSESTRINGNOW
    'Next I
    End Function
    Private Function PARSESTRINGNOW()
    Dim Atext As String
    Dim Btext As String
    Dim Ctext As String
    Dim Dtext As String
    Dim Etext As String
    Dim Ftext As String
    Dim Gtext As String
    Dim Htext As String
    Dim Itext As String
    Dim Jtext As String
    Dim count As Long
    If serinput = vbNullString Then
    Else
    count = Len(serinput)
    Atext = Mid$(serinput, InStr(serinput, "A") + 1, InStr(serinput, "B") - InStr(serinput, "A") - 1)
    Btext = Mid$(serinput, InStr(serinput, "B") + 1, InStr(serinput, "C") - InStr(serinput, "B") - 1)
    Ctext = Mid$(serinput, InStr(serinput, "C") + 1, InStr(serinput, "D") - InStr(serinput, "C") - 1)
    Dtext = Mid$(serinput, InStr(serinput, "D") + 1, InStr(serinput, "E") - InStr(serinput, "D") - 1)
    Etext = Mid$(serinput, InStr(serinput, "E") + 1, InStr(serinput, "F") - InStr(serinput, "E") - 1)
    Ftext = Mid$(serinput, InStr(serinput, "F") + 1, count - (InStr(serinput, "F") - 1))
    'MsgBox (Atext + " " + Btext + " " + Ctext + " " + Dtext + " " + Etext + " " + Ftext)
    SERIALINLOG.Text = "parsed data string: " + Atext + " " + Btext + " " + Ctext + " " + Dtext + " " + Etext + " " + Ftext + vbCrLf + oldlogtext
    End If
    End Function
    Public Sub bit1_Click()
    Call AddBits(1)
    End Sub
    Private Sub bit2_Click()
    Call AddBits(2)
    End Sub
    Private Sub bit3_Click()
    Call AddBits(3)
    End Sub
    Private Sub bit4_Click()
    Call AddBits(4)
    End Sub
    Private Sub BYTEOUT1_Click()
    allbitout8 = 129
    TransmitIt2
    End Sub
    Private Sub BYTEOUT2_Click()
    allbitout8 = 3
    TransmitIt2
    End Sub
    Private Sub BYTEOUT3_Click()
    allbitout8 = 7
    TransmitIt2
    End Sub
    Private Sub BYTEOUT4_Click()
    allbitout8 = 15
    TransmitIt2
    End Sub
    Private Sub BYTEOUT5_Click()
    allbitout8 = 11
    TransmitIt2
    End Sub
    Private Sub Command1_Click()
    allbitout8 = 255
    TransmitIt2
    End Sub
    Private Sub Command2_Click()
    MSComm1.Output = Chr$(254) & Chr$(1)
    End Sub
    Private Sub Command3_Click()
    MSComm1.Output = Chr$(254) & Chr$(2)
    End Sub
    Private Sub Command4_Click()
    Pause 300
    MSComm1.Output = Chr$(254) & Chr$(1) & Chr$(0)
    SERIALINLOG.Text = MSComm1.Input
    Pause 250
    Pause 250
    End Sub
    Private Sub Form_Initialize()
    bit1value = 0
    bit2value = 0
    bit3value = 0
    bit4value = 0
    allbitout = 0
    recadd = 0
    allbitout8 = 0
    End Sub
    Private Function AddBits(whichbit As Integer)
    If whichbit = 1 Then
    If bit1.Value = 0 Then
    bit1value = 0
    Else
    bit1value = 1
    End If
    'MsgBox ("bit1")
    End If
    If whichbit = 2 Then
    If bit2.Value = 0 Then
    bit2value = 0
    Else
    bit2value = 2
    End If
    'MsgBox ("bit2")
    End If
    If whichbit = 3 Then
    If bit3.Value = 0 Then
    bit3value = 0
    Else
    bit3value = 4
    End If
    'MsgBox ("bit3")
    End If
    If whichbit = 4 Then
    If bit4.Value = 0 Then
    bit4value = 0
    Else
    bit4value = 8
    End If
    'MsgBox ("bit4")
    End If
    allbitout = bit1value + bit2value + bit3value + bit4value
    'MsgBox (allbitout)
    'fourbitbyte.Text = allbitout
    Call TransmitIt
    End Function
    Private Sub Form_Load()
    MSComm1.Settings = "2400,N,8,1"
    MSComm1.CommPort = 1
    MSComm1.PortOpen = True
    End Sub
    Public Sub Pause(milli As Long)
    Sleep (milli)
    End Sub
    Private Sub Form_Unload(Cancel As Integer)
    If MSComm1.PortOpen = True Then
    MSComm1.PortOpen = False
    End If
    End Sub
    Jul 2005
    added this to the vb program to poll the serial port input gave it a 235ms interval
    Private Sub Timer1_Timer()
    End Sub
    Jul 2005
    Hooked up my Pic's recieve directly to the RX to confirm that the 2 programs resulted in seeing the data in the log window.. works resonably we'll when directly connected..
    still not at all through the PIC>PC TWS>RWS. the best i get is when i use the digital output the data is all strange charecters. this happens regardless of weither the pic side is on or off.
    RYTECH, Have you looked at the output from the receiver with no RF being generated? You probably have all kinds of switching going on at the output of the receiver as these types of receivers use a data slicer for comparing the signal strength of the incomming signal. These types of receivers need to have a Sync or Wakeup data stream sent before the actual data to condition the data slicer integrator. During times of no RF reception the integrator is allowed to discharge and is made more sensitive to background noise. If the PC side of the system is allowed to receive this output signal then it will interpret it as random data by the uart. That is why you need to send a stream of 1's and 0's to condition the receiver and then send a preamble pattern then look for the fixed pattern before accepting the received data from the RS232 port. I hope this all makes sense......
    psymansays's Avatar
    psymansays Guest
    Default TX / RX Frequencies
    Hi!
    I think you need to run you PC-transmitting-to-PIC pair at a different frequency than your PIC-transmitting-to-PC pair, or you can only do half-duplex communication without interference. That could explain some of your garbled received data.
    skimask's Avatar
    skimask Guest
    Cool
    Quote Originally Posted by psymansays View Post
    Hi!
    Nothing like bumping up a post that's over 2 years old...
    Jul 2005
    Skimask ur right it is quite old, I regularily refer to archived or old posts for help... I welcome and encourage people to post to old threads... u never know when new information might make the difference for someone...
  1. Interrupt and Serial communication to PC.
    By obaskirt in forum mel PIC BASIC
    Last Post: - 17th June 2005, 21:01
  2. Serial Pic to Pic using HSER
    Last Post: - 12th March 2005, 00:14
  3. Pic To Pic Serial Communication?
    By ngeronikolos in forum mel PIC BASIC Pro
    Last Post: - 5th February 2005, 01:59
  4. Serial communication PIC to PIC help.
    By Rubicon in forum mel PIC BASIC Pro
    Last Post: - 24th January 2005, 16:45
  5. PIC to PIC Serial Communication
    By v_merino in forum mel PIC BASIC Pro
    Last Post: - 23rd July 2004, 08:05
