HX711 driver code
Results 1 to 5 of 5
    Jan 2018
    Red face HX711 driver code
    Hi
    I have 18F452 pic . I want to use HX711 chip with 18F452 . I searched example code on the internet . But I cant find the example code that is written by pic basic
    Please help me
    Jan 2011
    Harare
    Default Re: HX711 driver code
    Hello Povulon,
    Did you had any luck with the HX711 code?
    Yves
    And now I have the same question
    Sep 2009
    You can try this:
     Hx711Cnt var Word
     I var Byte
     GraM var word
     GraMM var word
     SigN var byte
    Symbol dataa = PORTB.2
    Symbol clock = PORTB.3
    input dataa
    output clock
    I=0
    LoadCellA:
     dataa = 1:clock = 0: Hx711Cnt = 0
     While dataa = 1 : Wend
     For i = 0 To 15
       High clock
       Hx711Cnt = Hx711Cnt <<1
       Low clock
       if dataa=1 then Hx711Cnt=Hx711Cnt+1
     Next
     High clock
     Hx711Cnt = Hx711Cnt^32768
     gram=32768-Hx711Cnt
     'gram=gram-65477' zero
     IF gram.15 THEN  'negative values
         gram = ~gram + 1
         Sign = "-"
         Sign=" "
    disable
    gram=gram*11627   'scale values
    gramm=div32 10000
     enable
     LCDOUT $FE, 1
     LcdOut $FE,$80, "Tara=",sign,dec(gramm)
    GoTo LoadCellA
    EDIT: Not my code, but I helped to make it work...
    Thanks, will give it a try!
  1. Replies: 14
    Last Post: - 1st October 2012, 10:13
  2. MOSFET driver
    By showtime in forum mel PIC BASIC Pro
    Last Post: - 21st October 2007, 22:07
  3. i need driver code for infineon's sle4428
    By steve_st23 in forum General
    Last Post: - 5th March 2006, 17:20
  4. 7-Segment Driver
    By NavMicroSystems in forum Off Topic
    Last Post: - 13th April 2005, 14:50
  5. Driver code for 14 segment LED display
    By Durward Searcy in forum mel PIC BASIC Pro
    Last Post: - 12th December 2004, 20:08
