troubles with serial communication
Results 1 to 8 of 8
    Jan 2013
    Default troubles with serial communication
    hello all, I have problems with this code, do not know why it does not work,
    compiles fine without errors. I appreciate any help,
    this is the code:
    'P16f88_Tx
    INCLUDE "modedefs.bas"
    ansel =% 00000000
    Led var PORTB.4
    Var BotonA PORTB.1
    led high
    led low
    transmit:
    if botona = 0 then Send 1
    led low
    goto transmit
    Send 1:
    led high
    serout PORTB.0, T1200, ["A"]
    goto transmit
    'P16f88_Rx
    ansel =% 00000000
    VAR leda PORTB.1
    var data byte
    high leda
    pause 250
    leda low
    receive:
    PORTB.0 serin, T1200, [data]
    if data = "A" then one
    leda low
    goto receive
    one:
    high leda
    goto receive
    regards!
    Default Re: troubles with serial communication
    You're got to be kidding me, does THAT code really compile without errors?
    I see at least 8 errors (that's about one error every 4th line of code) preventing it from compiling without errors, for example:
    Var BotonA PORTB.1 - should be BotonA VAR PortB.1
    led high - should be high led
    PORTB.0 serin, T1200, [data] - should be Serin PortB.0, T1200, [data][/i]
    Miami, Florida USA
    Make sure you configure PORTB.0 as an output port with the TRISB register.
    Anonymous
    Nov 2007
    West Covina, CA
    I saw too many errors then would not compile without too many errors.
    I fixed the reported errors until it compiled without any, but did not test your code.
    Compare them and test.
    'P16f88_Tx
    ansel = %00000000
    Led var PORTB.4
    BotonA Var  PORTB.1
    high led
    low led
    transmit:
    if botona = 0 then Send_1
    low led
    goto transmit
    Send_1:
    high led
    goto transmit
    'P16f88_Rx
    ansel = %00000000
    leda VAR PORTB.1
    RX_data var byte
    high leda
    pause 250
    low leda
    receive:
    serin PORTB.0, T1200, [RX_data]
    if RX_data = "A" then one
    low leda
    goto receive
    one:
    high leda
    goto receive
    Louie
    Miami, Florida USA
    Also, the TRISB register should be set properly.
    Anonymous
    May 2008
    Italy
    In addition to Louie's correction you need to set the oscillator register and Port register. Add the following Lines of code:
    CMCOM = 7 ' comparator off
    OSCCON = %01100010 ' oscillator @ 4 MHz
    TrisB =%00000010 'for Tx device ' pin B.1 is an input all other outputs
    TrisB =%00000001 'for Rx device ' pin B.0 is an input all other outputs
    Cheers
    Al.
    Jan 2013
    hello, thank you very much for responding, proves and tell you how I was.
    regards!
    Jan 2013
    thank you all, sorry for so late to respond, the program I worked perfectly.
    Greetings!
  1. Serial rf communication
    By tazntex in forum General
    Last Post: - 2nd August 2008, 16:27
  2. Serial Communication
    By morris in forum Serial
    Last Post: - 16th December 2006, 12:35
  3. Serial Communication
    By micah4242 in forum mel PIC BASIC Pro
    Last Post: - 25th August 2006, 14:09
  4. Serial Communication
    By Travin77 in forum mel PIC BASIC Pro
    Last Post: - 11th April 2006, 05:29
  5. Serial Communication
    By Keith in forum mel PIC BASIC Pro
    Last Post: - 4th March 2005, 23:56
