PortA.4 problem
Results 1 to 5 of 5
Thread: PortA.4 problem
    Jul 2004
    CA
    Angry PortA.4 problem
    Hi Forum,
    I have a series of LEDs connected to several ports in the PIC18F6620. My program is very simple in that I am only turning the LEDs On and Off one at a time. I have set the correct TRIS registers to make the usable pins as Output pins, the problem I am getting is that, why does the LEDs in PortA.4 not turn On. I have attached my code below: Can you please help. thanks
    Srig
    PORTA.4 is often an open drain type. So you can't drive a positive voltage with... well not directly as the other pins. try the append solution and post your result
    Crow-Baring the LED to turn it OFF is not very elegant and significantly adds to Global Warming when the LED is OFF.
    A better solution would be to connect one end of the Resitor to VDD (as you have it), the other end to the LED Anode, and the LED Kathode to PIC pin RA4. Drive the pin LOW for ON, and HIGH for OFF.
    PIC Coder's Avatar
    PIC Coder Guest
    Default PortA.4 Is Open Drain Type.
    This particular PortA.4 is open drain type so you have to take care it at hardware and software level.
    Bye
    @Melanie,
    I agree but some will absolutely prefer using the 'when the pin is high the LED is on' method to make the code more easy to understand if there's no flag that convert 0 to LedIsOn and 1 to LedIsOFF. You know what i mean!
    about the warming... (5*5)/300=0.083W ... human skin will produce more heat than this IMHO. But O.K for the unusefull current need.
  1. problem using GOSUB under interrupt
    By fobya71 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 20:52
  2. PORTA.4 problem in PIC16F84A ?
    By iugmoh in forum General
    Last Post: - 8th May 2008, 13:07
  3. USART Problem , but don't know where, in pc? or in PIC?
    Last Post: - 15th July 2007, 09:12
  4. 1 slave 1 master 1 MAX232 1 problem ?
    By SuB-ZeRo in forum mel PIC BASIC Pro
    Last Post: - 31st July 2005, 23:59
  5. PORTA.PinNo = 1 ' problem
    By frank small in forum mel PIC BASIC Pro
    Last Post: - 6th May 2004, 15:30
