Regenerating OSCCAL
Results 1 to 2 of 2
    Default Regenerating OSCCAL
    Here's something that might help some folks who have erased their OSCCAL values.
    I use a Pickit2, so I usually dont end up erasing the OSCCAL, and even if I do the Pickit2 generally regenerates it.
    But somehow, today, I had a chip that consistently said 'invalid OSCCAL', and sure enough it was erased. For some reason, Pickit2 failed to regenerate the value, although it was willing to let me specify it manually.
    So, just run the following code:
    FOR N = 1 to 255
    OSCCAL = N
    DEBUG #N,13,10
    PAUSE 200
    TOGGLE LED
    NEXT
    You'll get a string of incrementing numbers on your terminal, which are somewhat close to the value, as for these values the serial comms work.
    Just take the average of the first and the last, and there you are, your OCSCAL value.
    Dec 2005
    Default Re: Regenerating OSCCAL
    FOR N = 1 to 255 STEP 254
      OSCCAL = N
      DEBUG #N,13,10
      PAUSE 200
      TOGGLE LED
    NEXT
    Can we do this?
