12F675 and LM35 coding issue
Results 1 to 19 of 19
    Mar 2010
    Default 12F675 and LM35 coding issue
    Hi All,
    I'm a bit of a n00b when it comes to the PIC world, :-).
    I have developed previously in C, Cobol, VB6 (and .net) and C++, however I have decided to use PIC Basic for my embedded projects. I started with the simple blink (with and without button input) with a few LEDs hanging off the various ports, then worked up to rotating beacons (using PWM).
    My next mini learning project is to connect an LM35 to a 12F675. Along with the LM35 im connecting 3 LEDs, one white, one blue and one red simply to indicate a range of temps per color (i.e. if Temp < 30 then light the white LED etc) - Something I have got working through my Arduino and want to move to a more cost effective platform, :-).
    I have spent a few evenings mulling over it and changing the code, flashing and testing with not much success. I think my issues are stemming from my lack of understanding of the various registers used i.e. ANSEL, TRISIO etc, although I think I have read the datasheet correctly its still not giving me the desired result.
    Below is the code I have so far, please could you look and advise where I am going wrong?
    'Using PIC 12F675 with White LED connected to Pin 7, Blue LED on Pin 6,
    'Red LED on pin 7. Vdd is supplied as a regulated 5v to pin 1, Ground to pin 8.
    'LM 35 connected to Vdd and Ground + Centre pin connected to Pin 3 (AN3)
    'Pin 4 disconnected - Have tried connecting to Vdd with 10K res and turning MCLR_on with no sucess
    @ device pic12F675,INTRC_OSC,wdt_off,pwrt_on,protect_off,MCLR_off
    DEFINE CHAR_PACING 1000
    DEFINE OSC 4                                      'Set internal osc. To 4MHz
    '---------Define ADCin Parameters
    DEFINE ADC_BITS 10 'set number of bits in result
    DEFINE ADC_CLOCK 3 'set clock source (3=rc)
    DEFINE ADC_SAMPLEUS 50 'Set sampling time in uS
    '---------Define Vairables
    samples VAR WORD        ' Multiple A/D sample accumulator
    sample  VAR BYTE        ' Holds number of samples to take
    temp    VAR BYTE        ' Temperature storage
               ' clear Samples
    LED0	Con	0	' GPIO.0 = White LED
    LED1    CON 1   ' GPIO.1 = Blue LED
    LED2    CON 2   ' GPIO.2 = Red LED
    '--------Configuring I/O PORTS
    TRISIO = %010000   'set GPIO.0, GPIO.1, GPIO.2 as output (LEDs) & GPIO.4 as input
    ANSEL = %00111000 ' Set ADC clock = Frc, GPIO.4, 1 = A/D
    ADCON0 = %10000000 ' Right justify, use Vdd as Vref
    CMCON = 7
    '---------Main Program
    'Flash White LED on Start
    HIGH LED0
    Pause 500
    LOW LED0
    TEMP_READ:                                      'Subroutine to measure temp
                temp = 0                            'Clear temp register
                samples = 0                         'Clear samples register
                FOR sample = 1 TO 20                'Take 20 samples
                    ADCIN 3, temp                   ' Read AN3 into temp variable
                    samples = samples + temp
                    PAUSE 250                       ' Wait 1/4 seconds per reading
                NEXT sample
                    temp = samples/20               'Average over 20 samples (Every 5 seconds)
                    temp=(temp* 10)/2
    if TEMP <20 then      'Less than 20deg - White LED
        HIGH LED0
        LOW LED1
        LOW LED2
        GOTO             TEMP_READ
    IF TEMP >20 AND temp <30 then       'Between 20deg and 30deg - Blue
        LOW LED0
        HIGH LED1
        LOW LED2
        GOTO             TEMP_READ
    IF TEMP >30 then                    'Greater than 30deg - Red
        HIGH LED2
        LOW LED1
        LOW LED0
        GOTO             TEMP_READ
    You're not saying what the problem is, just that it doesn't do what you expect. As it looks quite alright to me I'm guessing you have problem with actually getting a reading from the ADC.
    ADCON0.0 turns on/off the ADC and you have it set to '0' = OFF and I'm not sure if the ADCIN command handles that bit automatically or not. Try setting it to '1' and see what happens.
    If your problem isn't related to the actual ADC then please elaborate a bit on what the problem is.
    Mar 2010
    Sorry, :-) you are right. Basically, its not doing anything currently. I have however checked the Data sheet and you are right, so I have changed the ADCON0 as follows: ADCON0 = %10001101, this should give me
    Bit - Setting
    0 - 1 = A/D Operating
    1 - A/D conversion Bit (I assume ADCIN would set this to 1 when running)
    2-3 - 11 = Channel 3 (AN3 / GPIO4)
    4-5 - Not Used
    6 - Vref, 0 = Vdd
    7 - 1= Right Justify
    However, even after this change and running it in the simulator (I don't have my breadboard etc here at work) it still does not even light up the <20 LED, :-(
    Kind Regards
    Rob
    Dec 2008
    Ploiesti, ROMANIA
    Default Try this...
               ' clear Samples
    CMCON = 7
    HIGH LED0
    Pause 500
    LOW LED0
                NEXT sample
                    temp=(temp* 10)/2
        HIGH LED0
        LOW LED1
        LOW LED2
    '    GOTO             TEMP_READ
        LOW LED0
        HIGH LED1
        LOW LED2
    '    GOTO             TEMP_READ
        HIGH LED2
        LOW LED1
        LOW LED0
     '   GOTO             TEMP_READ
    goto temp_read
    Sep 2005
    Campbell, CA
    It loloks to me that you are taking the 10-bit A/D samples and putting them in BYTE variable called TEMP. Changing TEMP to a word should certainly get you one more step.
    Charles Linquist
    Wink
    Hi, Bobbo
    Your main problem was scaling temps before displaying ...
    try this one :
    '*  Notice  : Copyright (c) 2010 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 05/03/2010                                        *
    '*  Name    : Temp 675'Using PIC 12F675 with White LED connected to Pin 7, Blue LED on Pin 6,
    @ device pic12F675,INTRC_OSC,wdt_on,pwrt_on,protect_off,MCLR_off
    'DEFINE CHAR_PACING 1000
    ADCON0 = %10001100 ' Right justify, use Vdd as Vref          ' Select channel 3 !!!
    CMCON = 7
    dummy   var word        ' DIV32 intermediate value
    temp    VAR BYTE        ' Temperature storage  ... might be a WORD !!! ( 0 - 1023 !!! )
    CLEAR           ' clear Variables
    GPIO = 0
    HIGH LED0
    Pause 500
    LOW LED0
    While 1
     TEMP_READ:                                      'Subroutine to measure temp   input = 10 mv/°C ~250 mv
                    ADCIN 3, temp                   ' Read AN3 into temp variable    result is ~ 50  ( .25 / 5 * 1024 )
                    PAUSE 12                       ' Wait 1/4 seconds per display ... (20 x 12 ms )
                NEXT sample
                    temp = samples/20               'Average over 20 samples (Every 5 seconds)   result is ~ 50
    '                temp=(temp* 10)/2               ' Result is 250 ... may overflow !!! so, the mult is no use !!!
    ' Trim to scale
      Dummy = 500 * temp                            ' 500 = 5000 mv full scale  / 10 mv per degree
      temp = DIV32 1024                               ' Number is Deg C Now ...
     SELECT CASE temp
        CASE is < 20    'Less than 20deg - White LED
        HIGH LED0
        LOW LED1
        LOW LED2
        CASE is < 31        'Between 20deg and 30deg - Blue
        LOW LED0
        HIGH LED1
        LOW LED2
        CASE is < 45         'Greater than 30deg - but less than 45 deg Red
        HIGH LED2
        LOW LED1
        LOW LED0
        CASE Else              ' Too cold !!! or dangerously hot ... let's blink everyting !!!
        HIGH LED0
        HIGH LED1
        HIGH LED2
        PAUSE 250
        LOW LED0
        LOW LED1
        LOW LED2
     END SELECT
    wend
    Interesting parts have been explained ...
    now, have a good bath ... you've sweat a lot on this one ... ROFL.
    Wink
    Hi, Charles
    The point is interesting as the maximum ADC value WITH THIS SENSOR ... will be ~ 256, and always far from the actual use of the sensor.
    so, we could use ADRESH as an open line indicator ....
    Sep 2005
    Campbell, CA
    LM35s don't have much output current, so you have to be careful with the load, but if you put a 100K ohm pull-up resistor to Vref, then you could detect an open sensor.
    Also look at the data sheet. They don't like capacitive loads, so if you have them located more than a few feet from the PIC, you should put a small resistor in series with the LM35 output pin.
    Charles Linquist
    Mar 2010
    Hectic weekend and I was starting to have withdrawal symptoms for my PIC and breadboard, :-)
    I didn't get a chance on the weekend to try this code, however, I must say, I struggled for ages trying to work out how to use the CASE statement and your example above has shown me where I went wrong.
    I have run the example in the simulator (I really need to start bringing my board and programmer to the office, :-) ) however, even with the pause set to 1 it seems to take forever to get through it - thus taking 20 samples @ Pause 250 each time takes hours, :-( - I even tried to set the sim to run Ultra fast, however it still takes ages to run the 20 samples. Looks like im going to have to run it on the chip tonight.
    Something im trying to get right in my head: If the LM35 outputs 10mv per deg, on a 5v reference, would 0deg be 2.50V or would the 2.50V be at the mid point of the units full range (110 to -40) i.e. 34Deg C? The data sheet does not seem to be this specific.
    Wink
    Vade retro, Satanas ... simulators are TOYS !!!
    Simulator ( which one ... might I understand ??? ) is a tool that doesn't "run" @ real speed ... so, pauses have to be divided per 50 or 100 not to become mad ... or even, have to be commented out !!!
    so, forget about this sim when some "pause" statements are there ...
    the program runs fine here ( I made a small demo where a counter increases temp from 0 to 100 instead of the 20 adc measures - was to verify the SELECT CASE structure, which is slightly different from "C" ... )
    for the LM35 ... take it simple !!! :
    0v for 0°C
    0.01v for 1°C
    0.10v for 10°C
    1.00v for 100 °C
    1.50 v for 150°C ... which is the maximum !!!
    so, 2.50 v is a fried chip !!!
    on a 5v00 ref ... 1.00v will show 1.00v / 5.00v x 1024 = 204 adc counts ... ( 1024 steps for full scale )
    just Work with REAL chips in a REAL World ... you'll get TRUE results ...
    Mar 2010
    Right, sitting on the couch @ home and was about to post about a strange result I was getting (unexpected LED lighting up)...until I checked my wiring again and I found the breadboard was still swapped from when I was doing the PWM routines with the LEDs, :-).
    Just checked with my DMM and it's 100% spot on, will adjust the CASEes to accommodate the 3 ranges I need and move it to a PCB, :-)
    Just wanted to say a really BIG thank you to everyone who took the time to help a newbie like me see the light (hehe no pun intended).
    I've decided to waterproof the LM35 and place it in the bath to show my 3yr old daughter when the water is too hot to touch - although she knows not to touch unless me or my wife has checked it first.
    My next project will be to take an input from my RC transmitter and drive a servo to start with, think I'm going to have to do quite a bit of reading, :-)
    Once again, thank you Alain, Fratello, Charles and Hendrik, appreciate the assistance - a couple of light bulbs have gone on in my head, looking forward to the journey PICs might lead me on.
    Be careful showing little ones you putting something in the bath with wires attached.
    Daddy did it with his gadget, I wonder what the radio sounds like under water....
    Mar 2010
    Hi Dave, point taken , :-), will make sure its enclosed and placed well before she sees it. Although when she was 2 she dropped a doll in by accident and since then has learn't not to put anything in the water unless its classified as a bath toy.
    Wink
    Hi, Bobbo
    one of our reviews ( Electronique pratique ) raised such a gadget :
    - LM339 comparator and NTC
    - Packed into a plastic photo roll box
    - 2 electrodes + a Darlington trans. to power on the device when dipped into the bath ... ( auto shut off with the towel ! )
    - powered with 3x2 small round Li batteries ...
    Do not ask me the scheme ... i do not have it !!!
    http://www.electroniquepratique.com/...idMg=29&id=316
    http://www.electroniquepratique.com/...idMg=42&id=505
    Mar 2010
    Now there's an awesome idea, will work out a way to waterproof the LM35 out the bottom of the case.
    Need to also work a way where you can press a button and the device will stay on for X number of minutes and then either sleep or turn off. Then she can press the button, drop it in and watch the colors, of course she will be taught that it is an "Authorized" bath time device, ;-)
    BTW, last night I managed to read the input signal from my RC Transmitter (Ok, pulsin is not so hard) from 2 channels and drive 3 different items as follows:
    1. LED for testing purposes - easy
    2. Pass through for the servo control
    3. Glow igniter (proportional depending on the throttle location as well as always on depending on the Gear channel switch) +-3A load - Running through a FET - I learn't how to use these in 1 night, :-) I'm quite chuffed to understand how these work now, it opens up a range of possibilities as now I can switch fairly high loads from the PIC.
    Thanks Alain, I noticed you are on RC Groups as well, hope to bump into you there as well in the future, I'll begin posting my autopilot build there soon, planning to use PICs as fail safes for the main navigation / stabilization hardware, :-)
    Wink
    Hi, Bobbo
    For the Glow-igniter, I've published an advanced one ... several years ago.
    Article is written in French ( ... ! ) so, the question ...
    Do you read French ??? ( even under torture ...)
    Mar 2010
    Alain,
    My French is nowhere near as good as your English, :-)
    Thankfully, the internet has given us google translate which works quite well with french and where it stumbles I can normally work out the meaning when put into the correct context.
    I've had a look around but am a bit confused around 2 things.
    1. I'll need a jumper to allow the user to input "Programming mode" - Not sure where to put it, would GP3 with a pulldown res work or can I use any other GP?
    2. Once I have read the value I can flash the LED a couple of times to show the user the chip has the reading, however, when the chip reboots, how do i store the value in memory that will not be reset on a power cycle, :-)
    Easy to explain but quite complex principles to work out, :-) seems like i might be getting ahead of myself.
    Hi, Bobbo
    have a look to this program ...
    It's not the glow driver ( you would be lost @ first lines ...) but a lighting system shown on RC Groups.
    as processor is a 12F675 ... it will be easier.
    But main pulse handling routines are in ...
    Mar 2010
    Ok, wow, that code has some awesome information in it, going to be fun getting this to work.
    You've also set a standard as to what my code should look like, :-) I was never very good at commenting when I did programming, am learning that its almost mandatory in the real world, :-).
    Thanks a mil
    Rob
  1. 12F675 cant serout to PC
    By ruijc in forum General
    Last Post: - 3rd December 2007, 01:11
