8x8 LED Matrix - Car / Boat Game (16F872)
Results 1 to 5 of 5
    Feb 2007
    Default 8x8 LED Matrix - Car / Boat Game (16F872)
    Hi again
    Have modified my last post
    http://www.picbasic.co.uk/forum/showthread.php?t=10834
    8x8 LED Matrix display, scrolling the temperature in degrees C.
    have added 2 buttons to the circuit (up & down)
    the project still scrolls the temperature, but when 1 of the buttons is pushed the game starts.
    the display scrolls a road / river, which you have to navigate by moving the postion of the car/boat up or down, shown in the 1st column on the left.
    at the end of the game after a collision the level reached is scrolled across the display.
    the code is far from perfect....but seems to work ok...im still learning!
    VIDEO:
    Feb 2014
    Default Re: 8x8 LED Matrix - Car / Boat Game (16F872)
    what is UIN2004AN
    Oct 2009
    Utah, USA
    It's a ULN2004AN
    http://www.mouser.com/ProductDetail/...L5%252bUI3Dw==
    It is a darlington transistor high current driver capable of 500mA per channel.
    They also make an 8 bit one ULN2803 that would eliminate the need for a second package.
    Dwight
    https://www.noisebridge.net/images/c/cf/ULN2004.pdf
    The UTC ULN2004 are high-voltage, high-current darlington
    drivers comprised of seven NPN darlington pairs.
    EDIT: Weird, Heckler's post didn't show up until after I posted?
    That's my excuse and I'm sticking to it.
    Feb 2007
    when I 1st came up with this I had some ULN2004's at home, and wasn't aware of the ULN2803 existing
    both ULN2004's can be swopped for 1 ULN2803 which will work the same
    cheers
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 04:59
  3. USB Controlled - 8x8 LED Dot Matrix
    By mindthomas in forum Adverts
    Last Post: - 22nd February 2009, 20:08
  4. MY FIRST scrolling 8X8 LED
    Last Post: - 15th August 2008, 16:23
  5. LCD will not start
