Roman Black Sound (btc)
Results 1 to 40 of 58
    I did some experimenting with storing the sound in external EEPROM.
    And for sure, you have to be using the MSSP module to read the data.
    SHIFTIN or I2CREAD can't keep up with the higher bitrates.
    I tried contacting Roman several times by email, and never got an answer, so I kind of forgot about it, and haven't done anymore with it.
    Jan 2007
    Brazil
    I recorded a 5 sec 8-bit mono 22050Hz sound... then I stored it in the 24C512..
    then I put this on the 16F877:
    LOOP:
          I2CREAD DPIN,CPIN,$A0,B0,[ATUAL, PROX] ' Read 2 locations in a row
          B0 = 2
          REPEAT
            while F_nova = 0 : wend
                f_nova = 0
                I2CREAD DPIN,CPIN,$A0,B0,[PROX]
                b0 = b0 + 1
          'UNTIL B0 = 4997
    goto loop
    disable
    PPL:    PIR1.0 = 0
            TMR1H = LOAD.HIGHBYTE
            TMR1L = LOAD.LOWBYTE
            BUFFER.6 = ATUAL.7
            PORTD.1 = BUFFER.6
            PORTD.0 = BUFFER.7
            BUFFER = BUFFER << 1
            ATUAL = ATUAL << 1
            f_ctrl = F_Ctrl + 1
            if F_ctrl = 8 then
                F_NOVA = 1
                f_ctrl = 0
                atual = prox
    ENABLE
    Well, what I get is a slow and noise sound of what I had recorded. It is recognizable but isn't that good..
    I've tried increasing TMR1 interrupt but it did not make a difference...
    So, next steps:
    I'll try to user asm interrupts (instant interrupt..DT)
    try not to use I2CREAD..(editing: So, i've got to use MSSP..... Well, I suspect that there is no @ HI2CREAD yet, right? )
    Well, that is all..
    danke schön..
    Sylvio,
    Darrel, have a look at the attached files. It might help on the audio compression project.
    Please rename the files to *.rar and then de-compress them.
    Hi Ioannis,
    What are they?
    Roman's btc convertor creates the smallest sound files I've ever seen.
    Can't imagine more compression being able to do anything without ruining the sound.
    I don't use RAR.
    Not brave enough to download free programs from a couple of brothers in Russia.
    Hi Darrel. This is an article from the EDN magazine, February 1999. I thought to save you from the trouble to search the site and download it.
    It uses the PIC16C556/12C672 and ADPCM DECODER/ENCODER techniques.
    I don't know if they produce smaller files than Romans as I have not tested yet.
    OK, i will try to zip it and break it into 2 files. I hope windows ZIP can do that.
    I made the files *png. Hope that are readable.
    Cambridge UK
    How do you convert the .BTC file generated by Romans BTC Sound encoder to a hex file?
    Just done a quick search on here and using google, could not find anything that helped.....Found a HEX editor, going to see if I can encode some sound!!
    regards
  1. Delayed output 10 secs
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 14th October 2011, 07:28
  2. new to PIC programming could really do with some help
    By karenhornby in forum mel PIC BASIC Pro
    Last Post: - 5th March 2008, 15:03
  3. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  4. Sound and sound control with minimal parts
    By bartman in forum General
    Last Post: - 18th January 2005, 15:08
  5. Re: quick fix for sound command?
    Last Post: - 9th July 2004, 02:44
