Chris,
The prescaler can be changed with T1CON.
$31 = 1:8
$21 = 1:4
$11 = 1:2
$01 = 1:1
And the Timer is reloaded by putting values in TMR1H:TMR1L.
So first, decide what frequency you need, I'll go with 100hz.
Then, go to this thread...
Testing Forms [TimerCalc] Working I think?
http://www.picbasic.co.uk/forum/showthread.php?t=2031
Enter the OSC value you are using, say 20mhz.
I'll also go with 1:1 prescaler, enter that. (ok, it's already there)
Then enter 100 in the Freq field at the bottom.
Now you can see that it will take a total of 50,000 counts (ticks) to achieve 100hz.
Decide what resolution you want for the Duty-Cycle. ummm, 8-bit (256).
Now you just calculate the ON count from that with...
50000*DutyCycle/256 which is the same thing as...
50000*/DutyCycle in PBP
and the OFF count is 50000 - ONcount
Ok, so let's put that into the Blinky Light example
; Initialize your hardware first.
INCLUDE "DT_INTS-18.bas" ' Base Interrupt System
INCLUDE "ReEnterPBP-18.bas" ' Include if using PBP interrupts
LED1 VAR PORTB.1
DutyCycle VAR BYTE
TotalCount CON 50000
ONcount VAR WORD
OFFcount VAR WORD
INT_Handler TMR1_INT, _ToggleLED1, PBP, yes
T1CON = $00 ; Prescaler=1:1, TMR OFF
@ INT_ENABLE TMR1_INT ; enable Timer 1 interrupts
FOR DutyCycle = 0 TO 255 ; Ramp up
GOSUB SetDutyCycle
PAUSE 5
NEXT DutyCycle
FOR DutyCycle = 254 TO 1 STEP -1 ; Ramp down
GOSUB SetDutyCycle
PAUSE 5
NEXT DutyCycle
GOTO Main
SetDutyCycle:
ONcount = TotalCount*/DutyCycle
OFFcount = TotalCount - ONcount
IF DutyCycle = 0 THEN
T1CON.0 = 0 ; turn off timer
LOW LED1 ; idle LOW
T1CON.0 = 1 ; timer on if DutyCycle > 0
DISABLE DEBUG
'---[TMR1 - interrupt handler]------------------------------------------------
@Timer1=TMR1L ; map timer registers to a word variable
Timer1 VAR WORD EXT
ToggleLED1:
IF LED1 THEN
LOW LED1
T1CON.0 = 0 ; stop the timer
Timer1 = OFFcount ; Load OFF count
T1CON.0 = 1 ; start timer
HIGH LED1
Timer1 = ONcount ; Load ON count
@ INT_RETURN
ENABLE DEBUG
