InfraRed ramblings
+ Reply to Thread
Results 1 to 3 of 3
    Default InfraRed ramblings
    Using this 940nm LED set on Amazon: https://www.amazon.ca/dp/B01HGIQ8NG
    Can I have the transmitter LED on without any pulsing? (resistor values are temporary, did not do any calculations yet)
    Name:  IR schematic.png
    This circuit was inspired by this tutorial: https://www.instructables.com/Intro-to-IR-Circuits/
    I just want to detect a hole in a disk; no communication.
    Examples on google often use 38kHz or 56kHz, but their receiver has 3 pins; VDD, VSS and DAT. That leads to me to believe there's more going on in that receiver.
    This guy has a really nice way to calculate the values:
    Default Re: InfraRed ramblings
    if there is any ambient light leakage a ir sensor like SEN-19018 would be better than a photo diode, with the bonus of making
    led modulation unnecessary too.
    if the distance between led and sensor is small [under 10mm] then you only need a small current through led 5 to 20 mA
    would be heaps
    There will be minimal light leakage. These will be on either side of a disk, as close as I can get them.
    I plan on putting black heatshrink over the LEDs as close as I can to the rotating disk.
    This will be used as a way to home a stepper (fuel gauge on a flight sim); I need to find 0 easily. I'm sure there as more precise techniques, but I'm looking for a simple low-cost solution that works.
    I was planning on using these steppers: https://www.amazon.ca/dp/B0CPSLS944
  1. InfraRed communication
    By Alexey in forum General
    Last Post: - 15th February 2020, 05:53
  2. InfraRed Data Com
    By rayzrocket in forum Off Topic
    Last Post: - 29th March 2010, 15:42
  3. Infrared x PIC
    By ewandeur in forum mel PIC BASIC Pro
    Last Post: - 29th December 2009, 18:30
  4. infrared help
    By griffin in forum mel PIC BASIC Pro
    Last Post: - 30th December 2008, 05:34
  5. infrared
    By bmohnsen in forum General
    Last Post: - 2nd May 2007, 16:35
