Timing issue
Results 1 to 10 of 10
Thread: Timing issue
    Default Re: Timing issue
    Three things ...
    1) you use the IOC interrupt ... so that rings the " Mismatch condition " bell in my head ... see Sleep datasheet chapter.
    2) Microchip recommends to place a NOP instruction just past the Sleep one, when using the feature this way.
    3) when you push a button ... you obviously release it one day ! makes two input changes ...
    try to add
    @ sleep
    @ nop
    If the GIE
    bit is clear (disabled), the device continues execution at
    the instruction after the
    SLEEP instruction. If the GIE bit
    is set (enabled), the device executes the instruction
    after the
    SLEEP instruction, then branches to the interrupt
    address (0004h). In cases where the execution of
    the instruction following
    SLEEP is not desirable, the
    user should have a
    NOP after the SLEEP
    instruction.
