I have the below program and want it to generate the following pwm signals.
1) 2khz HPWM this is working fine as shown by scope.
2) 25hz 50% duty SPWM this is working fine as shown by scope.
3) 25hz 7% duty SPWM this is not working correctly and is broken up and irregular.
4) 12hz Manual pause defined PWM, again this is not working correctly and the led I have to check the loop is not working
The loop1 is is not executing for some reason.
Perhaps something in my config/register setup?
It uses Darrells Instant interrupts and SPWM but I can't see anything obviously wrong. Can you?
'------------------------------ General configuration --------------------------
#config
__config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_OFF & _MCLRE_OFF & _BOREN_OFF & _CLKOUTEN_OFF & _FCMEN_OFF
__config _CONFIG2, _PLLEN_OFF & _LVP_OFF
DEFINE OSC 16 'Set PicBasic Pro processor speed to 16 Mhz (Must match oscillator value)
OSCCON = %01111010 'Sets internal osc to 16 Mhz (Default)
TRISA = %00000000 'PortA All Outputs
; Initialize your hardware first
CLEAR
INCLUDE "SPWM_INT.bas" ; Software PWM module
DEFINE SPWM_FREQ 25 ; SPWM Frequency
DEFINE SPWM_RES 100 ; SPWM Resolution
DutyVar1 VAR BYTE
DutyVar2 VAR BYTE
'Port Aliases
MotFsb VAR PORTA.4 'Define Pin A4 as MOTFSB
RedLed VAR PORTA.1 'Define Pin A1 as RedLed
SPWM_LIST macro ; Define Pin's to use for SPWM
SPWM_PIN PORTA, 0, _DutyVar1 ; and the associated DutyCycle variables
SPWM_PIN PORTA, 5, _DutyVar2 ; Notice the underscore before variables
SPWM_INIT SPWM_LIST ; Initialize the Pins
INT_Handler TMR1_INT, SPWMhandler, ASM, yes
@ INT_ENABLE TMR1_INT ; enable Timer 1 interrupts
;_____________________________________________________________________________
Main: ; Simple Demo
HPWM 1, 127, 2000 'Start 2khz 50% Duty HPWM
DutyVar1 = 7 'Set MOTSTB to 7% Duty SPWM
DutyVar2 = 50 'Set MOTFSA to 50% Duty SPWM
Loop1: 'Bit Bang 12hz PWM
HIGH MotFsb
Pause 37
LOW MotFsb
Pause 45
toggle RedLed
goto Loop1
