Time to transfer data in EasyHID
Results 1 to 21 of 21
    Default Time to transfer data in EasyHID
    Does anyone else have a slight lag when transmitting data from the PC to PIC? Oddly enough transferring data from the PIC to PC is extremely fast.
    I'm wondering if it's just me and my lousy coding abilities or if the USB bus on my PC has a lot of overhead (I would expect that to affect traffic both ways).
    Yup, it was me.
    The transfer is faster than the human eye in both directions, awesome!
    Robert, i guess it's time for you to have a break and relax Hey, there's still 56.2 years remaining now for your project?
    I have some Truck-mechanic problem and i will have to stay here for few days. Most of those pending job are on the test bench. I'm about to begin a 'Easy USB for dummies' short tutorial to be posted here. If i finish this house-bench-cleanning soon, i should have time to do it and post it here this week. I guess it could be handy for few guys here. Well i guess.
    I finally got everything up and running. VB6 is fun once you get into the hang of things, but there's so many tricks, so much flexibility. Programming the PC interface is going to be another project in itself.
    Now I'm getting back in that VB6 tutorial I started a few months ago; I'm at the database access section. I defined a basic database for my application in Access (saved in 2000 format), but I'm getting an error when I try to use it in VB6; something about unknown database format. I figure VB6 can only read an older format like Access97 which probably means having to work in Windows '98 again.
    Looks like I might have to set up that other PC with dual partition after all (Win XP and '98). I've been putting that off for a while now, ugh...
    Feb 2003
    Quote Originally Posted by Demon
    Access 2000 works fine with VB6.
    Add in Component "Microsoft ADO Data Control 6.0 (OLEDB)"
    I have the following declarations in my project
    Dim adoConn As New ADODB.Connection
    Dim adoRS As New ADODB.Recordset
    strConn = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source="
    strConn = strConn & "K:\HTML\db\KAT5AV.mdb"
    adoConn.ConnectionString = strConn
    adoConn.Open
    Its a couple of years since I wrote that program but I am pretty sure that your problem is the provider. I think Access 2000 needs Jet4 whereas Access97 was Jet 3.5.
    You definately dont need to revert to Win98 as I am running XP.
    I actually have a web front end for the database which I use for entering and editing data, my VB app only reads the database for sending commands out of a Comm port although there is no reason why it could be done the opposite way round with VB receiving data and inseeting records into a database that could then be read on a web browser.
    Any updates you need including service packs for VB6 should be on the Microsoft website.... somewhere!!!!
    HTH
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Thanks much!
    I tried installing Office 97 on Win XP, not a good idea. :lol:
    I'll try your suggestion after I spend some time with my girls.
    Ooops, missed that statement:
    "Add in Component "Microsoft ADO Data Control 6.0 (OLEDB)""
    I looked for it but I don't have it, at least not spelled that way. Can you tell me what the file name is for that reference? You can see it when you click on the reference. I might have better luck finding it that way.
    Feb 2003
    Hi Robert,
    I was thinking about this as I was out driving and realised I hadnt checked what references I had included.
    Microsoft DAO 3.6 Objects Library
    Microsoft ActiveX Data Objects 2.7 library
    You have added MDAC 2.8 which is newer than MDAC 2.7 that I have included but I have just tried with 2.8 and it works fine.
    Make sure you are using the JET4.0 provider not JET3.51
    http://www.devx.com/vb2themax/Tip/18535
    I just changed my code to
    strConn = "Provider=Microsoft.Jet.OLEDB.3.51;Data Source="
    adoConn.Open
    and got the error you are getting.
    http://support.microsoft.com/kb/q238401/
    says that This problem was first corrected in Visual Studio 6.0 Service Pack Service Pack 4
    Service pack available here
    http://msdn.microsoft.com/vstudio/do...6/default.aspx
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Thanks Keith, tried with them and I still get the error.
    I'm downloading service pack 6 now.
    EDIT: Nope, same error, unrecognized database format. Tried with Microsoft ActiveX Data Objects 2.7 library, I also tried inverting the 2 references in case priority was important, same error.
    I put the code when I load the form, is that ok?
    Private Sub Form_Load()
    strConn = strConn & "E:\EasyHID\Xk1 v2\USBProject\VisualBASIC\Modified code\NR2003.mdb"
    adoConn.Open
    End Sub
    Or should I make another subroutine for this?
    Feb 2003
    Its a COMPONENT not a REFERENCE
    Project>>Components (or CTRL+T)
    C:\Windows\System32\MSADODC.OCX
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Feb 2003
    adoConn.Open
    End Sub
    Thats exactly where I put it !
        adoConn.Open
        MSComm1.CommPort = 3
        If MSComm1.PortOpen = False Then MSComm1.PortOpen = True
    End Sub
    Having said that, the one big difference I see is that you declare your adoConn and adoRS within the subroutine therefore they are not global variables and once you leave Form_Load they arent accessable.
    Mine are declared in General Declarations.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Ok, fixed the Components and the code, still got the same error. Do you have more components or references?
    I checked in Access and I have version 2000 set by default. 2002 is there but not enabled.
    Feb 2003
    Just checked, the only other Component is Microsoft Comm Control 6.0 but that is for the serial port so is irrelevant.
    I do have one more reference.... OLE Automation ... maybe that is the problem. c:\windows\system32\stdole2.tlb
    If that doesnt work can you email me a copy of the database and I will see if I can open it.
    keith at diyha dot co dot uk
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Nope, not it, but I did notice one thing while I was checking Access. It says SP3 even though I just ran SP6. I think I screwed up the update.
    When the download says "Where do you want to extract the files?", where do I want it to go? Here?
    E:\Microsoft Office\Office10
    I had extracted to a temporary folder and ran SETUP.
    Feb 2003
    Just looked at my Laptop and Help>>About didnt seem to indicate a service pack version so I looked in the VB98 directory and all the files were dated 1998.
    I had the VB6 service pack on another machine so I extracted it to
    c:\temp\vb6sp6\
    and ran setupsp6.exe which installed the service pack. Didnt even have to reboot. Now the spash screen indicates SP6 and so does Help>>About
    Why are you going to the MS office folders when you are trying to update Visual Basic ?
    What I dont understand is why my laptop was working when I didnt have any service packs installed unless Windows XP already has some updated files that VB used.
    Before I installed the service pack I created a very basic project from scratch using just the components and references already discussed and using just the ado declarations and setup in Form_Load and that didnt produce any error.
    Beats me
    I'm wondering if it is the database that is messed up rather than VB
    Keith
    www.diyha.co.uk
    www.kat5.tv
    D'uh, 'cause I was rushing on my way out the door for an appointment and I looked at the wrong application. I just checked VB6, it is SP6.
    I'll mail you the database and see if you can run it. I click START and get that error.
    EDIT: Keith, I've uploaded the files to my site so you can download them whenever you want (details in email).
    GOT IT!
    Just above the database name in the Form Properties box there is an item called Connect. That had Access, I changed it to Access 2000 and it works. Thanks Keith!
    Feb 2003
    GOT IT!
    Dont you just love the way Microsoft have about 15 different ways to do everything !!!!
    I dont have either "Connect" or "DatabaseName" in my form properties so you must be using an object or control that I dont use.
    Glad its sorted
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Sorry, it wasn't on the Form, it was on the Data item with the left/right scroll bars in the middle of the screen.
    Hopefully we'll get a place where we can discuss this subject without polluting other threads. I don't consider it off-topic either 'cause it is very relevant to USB and EasyHID:
    http://www.picbasic.co.uk/forum/showthread.php?t=4490
    Feb 2003
    Ah!
    I dont have one of those in my project. Just added one and could see the properties you were referring to.
    Keith
    www.diyha.co.uk
    www.kat5.tv
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 04:47
  2. Nokia 3310 display text
    Last Post: - 26th August 2007, 03:39
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 14:50
  5. Sinus calculating !
    Last Post: - 28th November 2004, 23:56
