Syntax Question
Results 1 to 4 of 4
Thread: Syntax Question
    Oct 2003
    Australia
    Unhappy Syntax Question
    Hi I'm just learing the Basics here.. sorry if these questions seem too easy for you smarties out there....
    1.
    I can't explain why I can not assign a string of text to a variable... eg
    MyText VAR BYTE ' Assign the Variable
    MyText = "X" ' Place Letter X into MyText
    Above compiles Ok.. But,
    MyText VAR BYTE[5] ' Assign the Variable
    MyText = "HELLO" ' Place Text 'HELLO' into MyText
    Doesn't compile. Any Ideas???
    2.
    If I use SERIN2 to get a line of serial data into an array, is each character stored in the array as one string (like in a LOOKUP table), or as a group seperate elements?
    eg
    MyText VAR BYTE
    SERIN2 PININ, 188, [STR MyText\5]
    MyText = "HELLO" OR "H","E","L","L","O"
    Thanks if you can help
    Aw c'mon folks... somebody else answer some questions for a change...
    PBP doesn't handle strings... unless they're one byte long... so you have to be creative.
    1. Assigning a longer string...
    MyText var byte [5]
    MyText[0]="H"
    MyText[1]="E"
    MyText[2]="L"
    MyText[3]="L"
    MyText[4]="O"
    2. Serin will save to an array if you so tell it to. The result will be as per my example in 1 above.
    Melanie
    Oct 2003
    Australia
    How about using a binary number? How many bits can be allocated to a Constant? I know that there are 8 bits in a byte.
    I would like to use 10 bits if it works.
    eg
    MyNumber_0 CON %0000000111
    MyNumber_128 CON %1111111000
    Seems to compile ok.
    Would it work? I am using a 16F628 which is an 8 bit controller, but has 2048x14 program space....or doesn't matter because PBP compilies for 8 bits only? Your advice is much appreciated.
    If you spill out of eight bits then it becomes a word and you have up to sixteen bits to play with.
    Remember, you have three types of data element to play with, a bit, a byte and a word. Whatever you're doing must fit one of these.
    Melanie
  1. Math operations & Syntax?
    By kevj in forum mel PIC BASIC Pro
    Last Post: - 23rd February 2008, 01:40
  2. IF..THEN syntax
    By scaenix in forum mel PIC BASIC Pro
    Last Post: - 20th February 2007, 12:10
  3. Question for a math guru
    Last Post: - 22nd November 2006, 09:45
  4. Please answer my first question
    By John_001 in forum Off Topic
    Last Post: - 15th September 2006, 06:49
  5. Syntax error PIC16F684
    By milestag in forum mel PIC BASIC Pro
    Last Post: - 21st September 2005, 18:54
