Interface for 16f818
Results 1 to 5 of 5
    Apr 2008
    Default Interface for 16f818
    I'm want to how to wire my 16F818 PIC up for interface my with PC and want to read to data from the PIC using VB.
    I have a max233cpp chip and also RS232 to usb convertor.
    I have set reg sspcon bit 5 to 1 on PIC for data output as thats all I need to use.
    Any help would be great thanks.
    North Norfolk UK
    Welcome
    Quote Originally Posted by davekav View Post
    Any code/details would be great thanks
    Duncan
    __________________
    Apr 2008
    This is my first PIC Project and have enjoyed it so far but having trouble moving forward at the minute.
    Details:
    The PIC is been used for a prototype alarm system for toy car and hoping to then interface with PC to give a nice GUI and display which sensor was triggered.
    list p=16f818 ; list directive to define processor
    #include ; processor specific variable definitions
    errorlevel -302 ; suppress message 302 from list file
    __CONFIG H'3F10'
    ;***** VARIABLE DEFINITIONS
    OPTION_R EQU 81H ;Option Register
    ZEROBIT EQU 2 ;means ZEROBIT is bit 2.
    COUNT EQU 20H ;COUNT a register to count events.
    COUNTA EQU 21H
    ORG 0x000 ; processor reset vector
    goto main ; go to beginning of program
    ; SUBROUTINE SECTION.
    DELAY MOVLW 0xFF ;load Decimal FF in W register
    MOVWF COUNT ;load Count with contents of W register
    LOADCA MOVLW 0xFF ;load Decimal FF in W register
    MOVWF COUNTA ;load CountA with contents of W register
    DEC DECFSZ COUNTA,F;decrement counterA and skip next line if Z=0
    GOTO DEC ;if countA not 0 than go to DEC
    DECFSZ COUNT,F ;decrement counter1 and skip next line if Z=0
    GOTO LOADCA ;if count1 not 0 than go to LOADC2
    RETURN ;else jump out of subroutine
    ;FLASH LEDS
    LED BSF PORTA,0 ;Turn on A0
    BSF PORTA,1 ;Turn on A1
    BSF PORTA,2 ;Turn on A2
    BSF PORTA,3 ;Turn on A3
    CALL DELAY
    BCF PORTA,0 ;Turn off A0
    BCF PORTA,1 ;Turn off A1
    BCF PORTA,2 ;Turn off A2
    BCF PORTA,3 ;Turn off A3
    ;FLASHING LEDS
    LEDs BSF PORTA,0 ;Turn on A0
    CALL DELAY
    CALL DELAY
    GOTO LEDs
    ; CONFIGURATION SECTION.
    main BSF STATUS,5 ;change to bank1
    MOVLW B'11110000' ;Bits for mixed I/Os on portA
    MOVWF TRISA
    MOVLW B'00111011' ;Bits for mixed I/Os on portB
    MOVWF TRISB
    MOVLW B'00000000'
    MOVWF OSCCON ;oscillator 31.25kHz
    MOVLW B'00000111' ;prescaler is /256
    MOVWF OPTION_R ;TIMER is 1/32 secs
    BCF STATUS,5 ;return to bank0
    BSF SSPCON,5 ;Set bit 5 to high to enable RB1, RB2 as serial I/O ports
    CLRF PORTB ;clear portB register
    CLRF PORTA ;clear portA register
    CLRF COUNT ;clear count register
    CLRF COUNTA ;clear countA register
    ;Program starts now.
    ARM BTFSC PORTA,4 ;INPUT FOR TRANSMITTER
    GOTO ALED
    GOTO ARM
    ALED CALL LED ;CALL LED SUBROUTINE
    GOTO POLLING
    POLLING BTFSS PORTB,0 ;CHECK ULTRASOUND
    GOTO ALARM
    BTFSS PORTB,1 ;CHECK DOOR 1
    GOTO ALARM
    BTFSS PORTB,5 ;CHECK DOOR 2
    GOTO ALARM
    BTFSS PORTB,4 ;CHECK TILT SWITCH
    GOTO ALARM
    GOTO POLLING
    ALARM BSF PORTB,6 ;TURN ON ALARM
    CALL LEDs ;FLASH LEDs
    BTFSC PORTA,4 ;WAIT FOR PORT TO BE LOW
    GOTO ALARM
    CLRF PORTA
    ;BCF PORTA,6 ;TURN OFF ALARM
    ;BCF PORTA,0 ;Turn off A0
    ;BCF PORTA,1 ;Turn off A1
    ;BCF PORTA,2 ;Turn off A2
    ;BCF PORTA,3 ;Turn off A3
    GOTO ARM
    ; initialize eeprom locations
    ORG 0x2100
    DE 0x00, 0x01, 0x02, 0x03
    END ; directive 'end of program'
    So any help would be great also I'm using MPLAB V8 and a PICstart programmer to burn the PIC.
    Thanks again
    MSSP is for I2C/SPI devices.
    Why not using the Internal USART instead? Way simple! Check For SPBRG, TXSTA, RCSTA register... but yeah.. this pic don't have any UART/USART/EUSART... change to something else... 16F88, 16F628A... or Buy a copy of our beloved PICBASIC PRO COMPILER version... you will do it in seconds with it's built-in software serial features. Buy it HERE
    BUT 31.xxx KHz is not going to be really helpful... 4MHz at very least.
    For serious serial communication i would suggest an external crystal for now.
    Apr 2008
    I wish I could afford PICBASIC but can't at the minute. So How would I go about setting up SSP, would it work in the same way for RS232 connection.
  1. LCDOUT w/custom interface?
    By Mike, K8LH in forum PBP Extensions
    Last Post: - 3rd March 2015, 03:54
  2. MXcom "C-BUS" interface to PIC question
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 1st May 2014, 03:59
  3. Replies: 33
    Last Post: - 19th March 2010, 03:02
  4. 'SCI' interface
    By ecua64 in forum Off Topic
    Last Post: - 29th September 2005, 16:02
  5. User Configuration Interface in PBP
    By Radiance in forum mel PIC BASIC Pro
    Last Post: - 7th February 2004, 08:00
