Using Pic to listen to audio tones from car radar detector
Results 1 to 3 of 3
    Nov 2006
    Murrieta, CA
    Question Using Pic to listen to audio tones from car radar detector
    So i have Uniden R1 radar detector. This unit as well as many others has an audio output port for external speaker. I would like to feed that output to a pic to read the different tones for the bands K/Ka/Laser. each band having a different tone. I will use a PIC 16F628A (16F877A if i need more ports).
    Thanks.
    Default Re: Using Pic to listen to audio tones from car radar detector
    I would try building a voltage comparator and feeding the audio into it producing a square wave then reading the frequency.
    EN82fn
    What exactly you need the PIC to do? Produce an discrete output for every tone?
    If yes, maybe Capture Compare could help with this.
  1. HB100 radar module
    By louislouis in forum mel PIC BASIC Pro
    Last Post: - 17th July 2017, 18:29
  2. Low frequency audio level detector using PIC ADC?
    By HankMcSpank in forum General
    Last Post: - 3rd March 2011, 01:05
  3. Slot Car timer with pic 16f84a
    By Snap in forum Serial
    Last Post: - 5th July 2007, 04:58
  4. PIC Audio
    By toofastdave in forum mel PIC BASIC Pro
    Last Post: - 27th June 2007, 13:49
  5. 8 port Signal Loss Detector, possible to use a pic?
    Last Post: - 20th March 2006, 15:59
