Trouble with LCD 2x8 and sequential display of values
Results 1 to 31 of 31
    Dec 2008
    Ploiesti, ROMANIA
    Default Trouble with LCD 2x8 and sequential display of values
    Hello !
    I try to build one volt/termometer with 16F684 and 2x8 characters display. I wrote the code, all works ...fine, the "IN" temperature is shown for 8 seconds, the "OUT" temperature for next 8 seconds, and so on, and so on (the voltage is on second line permanent)....
    BUT : sometimes, the value of temperature "jump" to "0.0 'C", especially when the temperature decreases ?! I really don't understand why . I made many changes in "pause", in "Define LCD_COMMANDUS 2000" and "Define LCD_DATAUS 50" , I added/removed " WaitLoop1: While not DQ1 : Wend" , but without results...
    Any clue ? Thanks in advance !
    This is "the big part" of my code :
    Main :
    Gosub Get_Vbatt                           ' make a new measure
                TmpW = Vbatt * Vfs                    ' AD * 20480
              TmpW = Div32 1024                     '(AD * 20480) / 1024
    Gosub char_batt
            LcdOut $FE, $c0, symb ," ", dec TmpW dig 4,dec TmpW dig 3,",",dec TmpW dig 2, " V"
    Gosub StartTimer
    While seconds =< 8
    Part1:
        ' Start temp.conv.Sensor1
         OWOut DQ1, 1, [$CC, $44]
         OWOut DQ1, 1, [$CC, $BE]
           OWIn  DQ1, 2, [temperature1.byte0, temperature1.byte1]
            If Temperature1.15 then
                  Temperature1= ~Temperature1 +1
                  Twist1 = 1
            Endif
        Dummy1 = 625 * Temperature1
        TempC1 = DIV32 10
        TempC1 = (Temperature1 & $7FF) >> 4
        Float1 = ((Temperature1.Lowbyte & $0F ) * 25 )>>2
        Temperature1 = TempC1*100 + Float1
            If Twist1 then
                    V1= 10000 - Temperature1
                  Twist1 = 0
                  V1= 10000 + Temperature1
            EndIf
            If V1 >= 10000 then
                  Temperature1=V1-10000
                  Temperature1=10000-V1
            EndIf
        GoSub SelectSign
               If (temperature1/100) =>10 then
                    LcdOut $FE, $80, "I:", Sign1, DEC (Temperature1 / 100), ".", DEC Temperature1 dig 1, 0
                    LcdOut $FE, $80, "I:", Sign1, $14, DEC (Temperature1 / 100), ".", DEC Temperature1 dig 1, 0
                Endif
          Pause 500
    Wend
    While seconds >= 9 and seconds =< 17
    Part2 :
         OWOut DQ2, 1, [$CC, $44]
         OWOut DQ2, 1, [$CC, $BE]
          OWIn  DQ2, 2, [temperature2.byte0, temperature2.byte1]
            If Temperature2.15 then
              Temperature2= ~Temperature2 +1
              Twist2 = 1
            Endif
        Dummy2 = 625 * Temperature2
        TempC2 = DIV32 10
        TempC2 = (Temperature2 & $7FF) >> 4
        Float2 = ((Temperature2.Lowbyte & $0F ) * 25 )>>2
        Temperature2 = TempC2*100 + Float2
            If Twist2 then
                  V2= 10000 - Temperature2
                  Twist2 = 0
                  V2= 10000 + Temperature2
            EndIf
            If V2 >= 10000 then
                  Temperature2=V2-10000
                  Temperature2=10000-V2
            EndIf
        GoSub SelectSign
                If (temperature2/100) =>10 then
                    LcdOut $FE, $80, "O:", Sign2, DEC (Temperature2 / 100), ".", DEC Temperature2 dig 1, 0
                    LcdOut $FE, $80, "O:", Sign2, $14, DEC (Temperature2 / 100), ".", DEC Temperature2 dig 1, 0
                Endif
          Pause 500
    Wend
    Gosub ResetTime
    Goto Main
    I have in code "include elapsed.bas" of course...The internal osc is set to 4 MHz.
    Dec 2008
    Ploiesti, ROMANIA
    Default Re: Trouble with LCD 2x8 and sequential display of values
    Even in Proteus I see this trouble, if "Out" temperature decreases verry fast ...
    (Just remove final extension of files)
    Dec 2008
    Ploiesti, ROMANIA
    ...or another way to display sequential values of temperature(s), while - on second line- display the voltage ?!
    Have someone another ideea ? Thanks !
    Quote Originally Posted by fratello View Post
    ... BUT : sometimes, the value of temperature "jump" to "0.0 'C", ...
    I have in code "include elapsed.bas" ...
    1-Wire and interrupts don't get along very well together.
    1-Wire has some pretty strict timing requirements, and interrupts like to mess that up.
    You can get good readings, but you have to plan on bad data occasionally.
    Which means verifying the CRC, and checking for all 0's in the packet. The CRC will pass (incorrectly) with all 0's
    You can use the CRC routines from Tom Estes ... http://www.picbasic.co.uk/forum/showthread.php?t=1672
    If the CRC fails, just go back and read the temperature again, no need to do another conversion.
    That of course means you need to read the sensor as a Packet, instead of individual variables.
    You also need to wait for the conversion to complete, either by PAUSE'ING the required amount of time, or polling the busy bit.
    Currently, you are not waiting at all after a conversion command.
    Dec 2008
    Ploiesti, ROMANIA
    Thank You for support !
    ...it's another way to do this ?
    I don't think I have enough space for adding something like CRC routines in my code (using 16F684)...
    How about just throw away values that are outside of expected ranges? Like take a running average, and if the temp is way off, disregard it. That way, it can still be 0 deg C, but only if its close to the average temp.
    http://www.scalerobotics.com
    Dec 2008
    Ploiesti, ROMANIA
    Thank you all for support !
    Since the "timming" it's not so important , I made this change :
    Pause 800 ; because DS18B20 need 750 ms for conversion
    Twist1 = 1
    Endif
    ...and the display works fine now...despite the decrease of speed in display the changes of temperatures.
    Dec 2008
    Ploiesti, ROMANIA
    I rushed... still have, from time to time, "0.0 'c" on display, ONLY for sensor on DQ2 (out sensor) .... ....
    Aug 2008
    Portugal
    Why not you poll the busy bit, instead of the Pause 800 statment?
    I don't know your application, but you can also disable interrupts before the 1-wire stuff, and then enable them again.
    Thanks and Regards;
    Gadelhas
    Dec 2008
    Ploiesti, ROMANIA
    Quote Originally Posted by gadelhas View Post
    Thanks for help ! How can I make this ? The most part of code it's in post #1...
    Aug 2008
    Portugal
    Can you put the code of your interrupts stuff, because i don't see it in the code of the post #1
    Thanks and Regards;
    Gadelhas
    Dec 2008
    Ploiesti, ROMANIA
    I use just :
    "Include "Elapsed.bas"" ; for counting seconds
    without other interrupts...
    Aug 2008
    Portugal
    I use just :
    I believe that Elapsed.bas uses Timer 1, maybe Darrel can correct me, if so, do this
    @ INT_DISABLE   TMR1_INT
     '1 wire stuff
    @ INT_ENABLE   TMR1_INT
    Probabily the acurracy of the elapsed.bas would be affected.
    Thanks and Regards;
    Gadelhas
    Dec 2008
    Ploiesti, ROMANIA
    I think I made some mistakes ... ...
    Aug 2008
    Portugal
    Can you attache the files? ( your code and elapsed.bas)
    Thanks and Regards;
    Gadelhas
    Dec 2008
    Ploiesti, ROMANIA
    The code is in post #1 ; this is the "header" :
    @ DEVICE PIC16F684, INTRC_OSC_NOCLKOUT, WDT_OFF, PWRT_ON, BOD_OFF, MCLR_ON, PROTECT_ON
    TRISA= %00010000
    TRISC= %00110000
    CMCON0 = %00000111          ' Disable analog comparators.
    VRCON  = %00000000           ' Disable Comparator Voltage Reference
    ANSEL  = %00010000           ' Set pin (AN2) to analog input, the rest to digital
    ADCON0 = %10001101           ' Set up A/D converter - Right Just., VDD REF., CH 3, ON
    ADCON1 = %00110000           ' Set up A/D Converter clock source to internal RC
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50
    DEFINE LCD_DREG PORTC           ' LCD on port c
    DEFINE LCD_DBIT 0               ' Data bits C0..C3
    DEFINE LCD_RSREG PORTA          ' RS on PORTA
    DEFINE LCD_RSBIT 1              ' RS on A1
    DEFINE LCD_EREG PORTA           ' E on PORTA
    DEFINE LCD_EBIT 2               ' E on A2
    DEFINE LCD_BITS 4               ' LCD 4 bit mode
    DEFINE LCD_LINES 2              ' 2 line LCD display
    Define LCD_COMMANDUS 2000       ' Command Delay (uS)
    Define LCD_DATAUS 50            ' Data Delay (uS)
    Temperature1     Var    Word
    Temperature2     Var    Word
    TempC1           Var    Word
    TempC2           Var    Word
    Float1           Var    Word
    Float2           Var    Word
    Sign1         Var    Byte
    Sign2         Var    Byte
    DQ1         Var    PORTC.5 ' OUT SENSOR
    DQ2         Var    PORTC.4 '  IN SENSOR
    Twist1           Var    Bit
    Dummy1           Var    Byte
    V1               Var    Word
    Twist2           Var    Bit
    Dummy2           Var    Byte
    V2               Var    Word
    symb             Var    Byte
    Vfs             con     20480   ' 20,480v
    K16             con     61441   ' coefficiente filtro 15/16
    Vbatt           Var     Word    ' Vbatt filtrato
    TmpW            Var     Word
    Acc_Vbatt       Var     Word    ' accumulatore Vbatt filtrato * 16
    batt            Var     Word
    DS18B20_1_12bit CON %01111111   ' 750ms,   0.0625°C  (default)
    DS18B20_2_12bit CON %01111111   ' 750ms,   0.0625°C  (default)
    LCDOUT  254,64,4,10,4,0,0,0,0,0          ' Cust Char #0  ; http://www.darreltaylor.com/files/CustChar.htm
    LCDOUT  254,72,10,31,17,17,17,17,31,0    ' Cust Char #1
    LCDOUT  254,80,10,31,17,17,17,31,31,0    ' Cust Char #2
    LCDOUT  254,88,10,31,17,17,31,31,31,0    ' Cust Char #3
    LCDOUT  254,96,10,31,17,31,31,31,31,0    ' Cust Char #4
    LCDOUT  254,104,10,31,31,31,31,31,31,0   ' Cust Char #5
    LCDOUT  254,112,15,3,5,9,16,16,16,0      ' Cust Char #6
    LCDOUT  254,120,1,1,1,18,20,24,30,0      ' Cust Char #7
    include "Elapsed.bas"
    Twist1 = 0
    Twist2 = 0
    Pause 5000
    LcdOut $FE, $80," TERMO "
    LcdOut $FE, $C0,"  VOLT "
    PAUSE 3000
    LCDOUT $FE, 1, $FE, $0C                     ' Clear display, cursor off
    Pause 200
     ;Init Sensor 1
     OWOUT DQ1, 1, [$CC, $4E, 0, 0, DS18B20_1_12bit]
     OWOut DQ1, 1, [$CC, $48]                       ' Start temperature conversion
     OWOut DQ1, 1, [$CC, $B8]
     Pause 50
     Pause 50
     ;Init Sensor 2
     OWOUT DQ2, 1, [$CC, $4E, 0, 0, DS18B20_2_12bit]
     OWOut DQ2, 1, [$CC, $48]                       ' Start temperature conversion
     OWOut DQ2, 1, [$CC, $B8]
     Pause 50
     Pause 50
    More about "Elapsed.bas" (credits to Mr.Darrel !) here : http://www.picbasic.co.uk/forum/show...7473#post17473
    Thanks again for support !
    Aug 2008
    Portugal
    I copied your code, and i can not see that error, however, instead of the;
     '1 wire stuff
    try this;
        T1CON.0 = 0                   ; Turn OFF Timer1
     '1 wire stuff
        T1CON.0 = 1                   ; Turn ON Timer1
    Thanks and Regards;
    Gadelhas
    Dec 2008
    Ploiesti, ROMANIA
    I tried this way, but...the timer stop counting (so, I can't display 5 sec. IN and 5 sec. OUT) and the reading of sensor(s) it's not continous....like in my "original" code ...
    I want to read permanent the sensors (for sensing the variation of temperatures) and display the temperature, 5 seconds from first sensor, the next 5 seconds from second sensor, so on, so on ....
    Otherwise I can write the code like this :
    " display temperature 1
    pause 5000
    display temperature 2
    pause 5000
    goto loop "
    which is not a good option ...
    fratello,
    Try this hex file.
    It uses elapsed.bas, adds CRC checking and error correction, while only using 1375 WORDs.
    Yours was 1871 WORDs, so it also saves ~500 WORDs (~1/4 of total memory.)
    It should run on your .dsn, but the voltage will be off because I changed the circuit a little.
    I didn't have your code, so the battery icon is different.
    Dec 2008
    Ploiesti, ROMANIA
    Thank You so much ! I will try soon Your hardware ... I must (re) build the PCB.
    In Proteus I have some messages ... It's something wrong ?
    ...and the temperature on display don't follow the variation of sensor(s)-the new temperature is on display NEXT time when the temperature is show !
    Oh, OK.
    I din't see that your's kept up with changes during each period.
    I will fix that.
    I wasn't seeing the ADC clock error, but I'll take a look.
    Dec 2008
    Ploiesti, ROMANIA
    Thank You again for helping me !
    The code for batterie is this :
    ...post #16.
    Sorry, sometimes I get carried away ...
    '*  Name    : DT18x20_Fratello.pbp
    '*  Author  : Darrel Taylor
    '*  Date    : 2/19/2012
    '*  Version : 1.1 (2/24/2012)
    '*  Target  : 16F684 @ 4 mhz
    DEFINE  OSC 4
    CLEAR
    ;----[Main Options]---------------------------------------------------------
    TimeToShow CON 5                ; Seconds to show each temperature
    ;----[Battery Options]------------------------------------------------------
    Res1   CON 20000                ; Top Resistor of Voltage Divider
    Res2   CON 10000                ; Bottom Resistor of Divider
    VDD    CON 50                   ; VDD voltage
    MaxBat CON 140   ; 14.0V        ; Batt indicator Max
    MinBat CON 98    ;  9.8V        ; Batt indicator Min
    ;----[DS1820 Options]----Value----Default-----------------------------------
    DEFINE  DS1820_DECIMALS    1    ; 1
    DEFINE  DS18B20_ONLY       YES  ; NO
    DEFINE  DS1820_VERIFYCRC   YES  ; NO
    DEFINE  DS1820_USETIMEOUT  NO   ; YES
    MaxRetries  CON 4
    INCLUDE "DT18x20.pbp"           ; Include DT18x20 module
    ; --- To get the include file, Register at http://darreltaylor.com/whatsup/
    Inside   VAR PORTC.5            ; Pin assigned to Inside Sensor
    Outside  VAR PORTC.4            ; Pin assigned to Outside Sensor
    ;----[Elapsed Timer]--------------------------------------------------------
    INCLUDE "Elapsed.bas"
    ; --- To get the include file ... Go to ...
    ; --- http://www.pbpgroup.com/modules/wfsection/article.php?article
    GOSUB ResetTime
    ;----[LCD definitions]------------------------------------------------------
    DEFINE LCD_DREG  PORTC          ; LCD Data port
    DEFINE LCD_DBIT  0              ; starting Data bit (0 or 4)
    DEFINE LCD_EREG  PORTA          ; LCD Enable port
    DEFINE LCD_EBIT  2              ;     Enable bit
    DEFINE LCD_RSREG PORTA          ; LCD Register Select port
    DEFINE LCD_RSBIT 1              ;     Register Select bit
    DEFINE LCD_BITS  4              ; LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 2              ; number of lines on LCD
    DEFINE LCD_COMMANDUS 2000       ; Command delay time in us
    DEFINE LCD_DATAUS 50            ; Data delay time in us
    ;----[Analog options]-------------------------------------------------------
    DEFINE ADC_BITS  10
    DEFINE ADC_CLOCK  3
    ADCON0.7=1                    ; Right Justify A/D results
    ;----[Program Variables]----------------------------------------------------
    BattLevel  VAR BYTE             ; 0 - 10, 0=Empty  10=Full
    RawBattery VAR WORD
    Volts      VAR WORD
    LastVolts  VAR WORD : LastVolts=0
    Sensor     VAR BIT  : Sensor=1
    Char       VAR BYTE
    y          VAR BYTE
    Retries    VAR BYTE
    TempW      VAR WORD
    GIE        VAR INTCON.7
    ;----[Initialization]-------------------------------------------------------
    CMCON0=7                      ; disable Comparators
    ANSEL=0                       ; All Digital
    ADCON1=$30                    ; ADC_CLOCK is FRC
    LCDOUT $FE,1:PAUSE 250:LCDOUT $FE,1 ' Initialize LCD
    LCDOUT " TERMO- ",$FE,$C0,"  VOLT  "
    GOSUB StartConversions          ; get the first reading started
    PAUSE 4000
    GOSUB StartTimer                ; Start the Elapsed Timer
    Seconds=TimeToShow            ; Force 1st display on start-up
    SecondsChanged=1
    ;----[Main Program Loop]----------------------------------------------------
        IF SecondsChanged THEN
            SecondsChanged=0
            IF Seconds !=0 AND Seconds != TimeToShow THEN GOSUB StartConversions
            IF Seconds=TimeToShow THEN      ; on each period
                Seconds=0
                Sensor=!Sensor              ; Toggle sensors
                LCDOUT $FE,$80
                IF Sensor=0 THEN
                    LCDOUT "I:      "         ; Indicate Inside sensor
                    LCDOUT "O:      "         ; Indicate Outside sensor
        IF Sensor=0 THEN
            @  DS1820_Select  _Inside         ; Select Inside DS18x20 pin
            @  DS1820_Select  _Outside        ; Select Outside DS18x20 pin
        DS1820_Flags=0                      ; clear flags before Stat
        GIE=0                               ; disable interrupts
            @ DS1820_Stat                     ;   get sensor status
        GIE=1                               ; enable interrupts
        IF DS1820_Done THEN                   ; if conversion finished
            @ DS1820_Read                     ; try to read the temp
            Retries=0
          RetryRead:
            IF DS1820_Error=0 THEN          ; if there were no errors
                GOSUB TempToLCD               ; display TempC
            ELSE                              ;--- Error reading Sensor --------
                IF Retries < MaxRetries THEN
                    Retries=Retries + 1
                    @ DS1820_Read             ; try to read it again (no Conv)
                    GOTO RetryRead
                LCDOUT $FE,$82,"Error "
        GOSUB ReadVoltage
        PAUSE 100
    GOTO Main
    ;----[Start conversion on both sensors]-------------------------------------
    StartConversions:
        @  DS1820_Convert                     ; start conversion
    ;----[Display TempC on LCD]-------------------------------------------------
    TempToLCD:
        TempW=TempC
        LCDOUT $FE,$82
        IF ABS(TempW)/DS1820_DIG < 10 THEN LCDOUT " "
        IF TempW.15 THEN
            LCDOUT "-"                        ; if negative, display minus sign
            LCDOUT "+"
        TempW=ABS(TempW)                    ; get the positive value
        LCDOUT DEC TempW/DS1820_DIG           ; Display the Integer portion
        LCDOUT "."                            ;   display decimal point
        TempW=TempW//DS1820_DIG             ;   get decimal portion
        LCDOUT  DEC1 TempW DIG 0
        IF ABS(TempC) < 1000 THEN
            LCDOUT $DF
    ;----[Read battery voltage]-------------------------------------------------
    RT     CON Res1 + Res2                    ; Total Divider Resistance
    ReadVoltage:
        ADCIN 3, RawBattery
        Volts=RawBattery * Rt
        Volts=DIV32 Res2
        Volts=Volts * VDD
        Volts=DIV32 1023
        IF Volts != LastVolts THEN
            LastVolts=Volts
            LCDOUT $FE,$C1
            IF Volts/10 < 10 THEN LCDOUT " "
            LCDOUT " ",DEC Volts/10,",",DEC1 Volts Dig 0," V"
            IF Volts >= MaxBat THEN
                BattLevel=12
                IF Volts <= MinBat THEN
                    BattLevel=0
                    BattLevel=(Volts - MinBat +1) * 12 / (MaxBat - MinBat +1)
            GOSUB ShowBattery
    ;----[Show Battery Icon  0 - 12, 0=Empty  12=Full]--------------------------
    ShowBattery:
        lcdout $FE,$C0,1,$FE,$48,$0A,$1F
        for y=4 to 1 step -1
            if BattLevel >= (y * 3) then
                Char=$1F
                if BattLevel >= (y * 3 - 1) then
                    Char=$17
                    if BattLevel >= (y * 3 - 2) then
                        Char=$13
                        Char=$11
            lcdout Char
        next y
        lcdout $1F
    Dec 2008
    Ploiesti, ROMANIA
    A GREAT piece of code ! A VERRY GOOD EXAMPLE !!!
    As usual, I'm speechless...Thank YOU, Mr. Darrel !
    Dec 2008
    Ploiesti, ROMANIA
    Bad post, sorry...
    but I can' compile the code : "Cannot open file (Include file "P16F684.inc" not found)" ?!
    Dec 2008
    Ploiesti, ROMANIA
    I am so sorry ... ....
    What a dumb I am ...
    Of course, Mr. Darrel have the answer : http://www.picbasic.co.uk/forum/show...2195#post52195
    Everything works just fine !
    Dec 2008
    Ploiesti, ROMANIA
    Everything works just fine ! Thanks again, Mr.Darrel !
    One last (I hope ) request : Can this "lint" be removed ? I try to find another value for "LCDOUT $nn", but without good results ...
    Thanks !
    Two ways ...
    1) Add a 0 to the last LCDOUT ...
        lcdout $1F,0
    2) You can make the battery icon 1 pixel taller ...
                    BattLevel = (Volts - MinBat +1) * 15 / (MaxBat - MinBat +1)
            GOSUB ShowBattery
    ;----[Show Battery Icon  0 - 15, 0=Empty  15=Full]--------------------------
    ShowBattery:
        for y = 5 to 1 step -1
                Char = $1F
                    Char = $17
                        Char = $13
                        Char = $11
            lcdout Char
        next y
        lcdout $1F
    Dec 2008
    Ploiesti, ROMANIA
    Just finish to write my own code, based on previous source (see post #1 ), it's good for me ...BUT ...
    Of course, Mr.Darrel solution it's BETTER !
    I owe with some thousands of e-beer ! Thanks again !
    Dec 2008
    Ploiesti, ROMANIA
    This is how my car-dashboard will be (this is beta version ) ...
    The original is in the last picture.
    Aug 2008
    Portugal
    Congratulations! Very good Job!!!
    Thanks and Regards;
    Gadelhas
