Strange reading from RFID..need help
Results 1 to 4 of 4
    Jun 2011
    Philippines
    Default Strange reading from RFID..need help
    Hi, Sorry to post this here but I've been trying to read from an rfid module on PortC.7 and wanted it to send the data to pc using CDC. My problem is everytime I swipe the card it gives me different values..
    '*  Name    : RFID_Test.BAS                                     *
    '*  Notice  : Copyright (c) 2011 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 11/14/2011                                        *
    '*  Notes   : Pic18F4550, RFID, Servo Motor, Button             *
    '*          : Interrupt on Hardware usart Recieve               *
    asm
        __CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
        __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
        __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L  & _BORV_2_2L  & _VREGEN_ON_2L
        __CONFIG    _CONFIG2H, _WDT_OFF_2H
        __CONFIG    _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_ON_3H
        __CONFIG    _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _ICPRT_OFF_4L  & _XINST_OFF_4L & _DEBUG_OFF_4L
        endasm
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 0
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 5
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
            DEFINE OSC 48
            DEFINE HSER_RCSTA 90h ' enable serial port,
            define HSER_TXSTA 24h ' enable transmit,
            define HSER_SPBRG 25 ' set baudrate to 9600
            DEFINE HSER_CLOERR  1 ' automatic clear overrun error
            TRISC  = 000000    ' PORTC.7 is the RX input, PORTC.6 is the TX output
        '   Serial communication definition
    ADCON1 = 001111      'Set up ADCON1 register no matter what you're doing!!!!!!
    INCLUDE "cdc_desc.bas" 'Descriptor file    for CDC    serial demo
    INCLUDE "MODEDEFS.BAS"       ' Include Shiftin/out modes
    INCLUDE "DT_INTS-18.bas"     ' Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"  ' Include if using PBP interrupts
        '   Variable definition
    RCIF       VAR     PIR1.5     ' Receive  interrupt flag (1=full , 0=empty)
    TXIF       VAR     PIR1.4     ' Transmit interrupt flag (1=empty, 0=full)
    TRISC = 100000
    PortC = 000000
    led        var     PORTC.0
    led1       var     PORTC.1
    led2       var     PORTC.2
    holdoff    var     word
    SerialData var     byte[15]
    DataRec    var     byte[15]
    buffer     var     byte[20]
    flag1      var     byte
    flag1 = 0
    cnt        var     byte
    cnt1        var     byte
    cnt = 5
            INT_Handler   RX_INT,    _Getbytes,    PBP,  no
            INT_Handler     USB_INT,  _DoUSBSERVICE,   ASM,  yes
    ;----[Initialise USB and Interrupts]----------------------------------------
        PAUSE 100                    ; Allow VUSB to stabilize
        USBINIT                      ; initialize the USB driver
        USBSERVICE                   ; service it once
        UIE = $7F                    ; enable USB interrupts
        UEIE = $9F                   ; enable USB Error interrupts
    @   INT_ENABLE  USB_INT
    @   INT_ENABLE  RX_INT     ; enable RX_INT interrupts
    USBInit
    USBService
    Mainloop:
            USBService ' Must service USB regularly
            Lcdout $fe, 1        ' Clear screen
            Lcdout $fe, 128, "Val: "
            toggle led           'toggle led every loop for heartbeat
            if flag1 = 1 then
            Gosub readser
            '*****************INSERT**********************
            cnt1 = 1
            USBIn 3, buffer, cnt1,  Mainloop
            toggle led1
            Lcdout $fe, 128, "Hello World"
            pause 200
            goto Mainloop
    ;--------['ISR for RX_int interrupt]-------------------------------------
    Getbytes:
           While RCIF = 1     ' clear the buffer
            HSERIN 100,error,[SerialData] ' take it
           Wend
           High led2       'led to confirm program went to RX ISR
           flag1 = 1
    @ INT_RETURN
    ;----[Interrupt handler -- Service USB]-------------------------------------
    DoUSBSERVICE:
          USBSERVICE                   ; Run the SERVICE routines
    @ INT_RETURN
    error:
          Toggle led1
    @ INT_RETURN
    usbtx:
    USBOut 3, DataRec,5,usbtx
    readser:
             serin2 PortC.7, 84,[ DataRec]
             'Lcdout $fe, $c0, STR DataRec\13
             if DataRec > 0 then
             LCdout $fe, $c0,#DataRec
             gosub usbtx
             Lcdout $fe, 128, "Val:"
              flag1=0
             Low Led2
             ENdif
    Hardwre: Pic18F4550,@20Mhz, PBP2.6
    I appreciate any help.
    Jun 2011
    Philippines
    Default Re: Strange reading from RFID..need help
    Hi, can anyone point me to the right direction on how to capture data(codes from previous post) from HSERIN 100,error,[SerialData] to variable DataRec? I did some variations just to make it display on the LCD, it seems I can not. I appreciate any help(it's drving me nuts).
    Getbytes:
           cnt=0
            HSERIN 10,error,[Serialdata] ' take it
            DataRec[cnt]=SerialData[cnt]
            HSEROUT [DataRec[cnt]] ' take out
            cnt=cnt+1
           Wend
           LCdout $fe, $c0, DataRec
           Toggle led2       'led to confirm program went to RX ISR
           flag1 = 1
    Thanks in advance,
    tacbanon
    Something like this might work better, I think.
    http://melabs.com/samples/PBP-mixed/usart.htm
    But if you go with what you have can you display "Serialdata" to the LCD?
    Jun 2011
    Philippines
    Hello Dave, thanks for replying. I also tried to display Serialdata to LCD but no luck..this moved me to copy the content to DataRec variable but I also realized that this does not working also...I will check out the link you gave.
    thanks and regards,
    tacbanon
