Usb communication
Results 1 to 5 of 5
    Thumbs up Usb communication
    I have a device that is connected to PC through USB cable.How to communicate between device and PC?
    Make a program, and make sure the power supply is turned-on, or teach'em to speak louder... this assume a Microphone and speaker are intalled on both side
    USBDemo
    http://www.picbasic.co.uk/forum/showthread.php?t=5418
    Thumbs up Hi..............
    thank u for replying me........... but i did't get complet idea ............plz send if u have any code in VB or c# .............do u know about USB master to slave converter............
    The USBDemo link I gave should be more than enough to get started. It has VB6 code in. If you need .NET syntax, you may try to use the automatic Upgrade/converter tool.
    There's also a VB.NET template available at the following link
    http://www.picbasic.co.uk/forum/show...27&postcount=9
    If you know VB & C#, it shouldn't be that hard to convert that VB template to C#.
    Another alternative is to use Jan Axelson's codes
    http://www.lvr.com/hidpage.htm
    Not sure to understand what you mean, but I feel you might talk about USB OTG. If so, there's no USB OTG available for PIC16, PIC18, just for PIC24 & PIC32 family, and they're not supported by PBP.
    Oct 2003
    Australia
    Turn on the scanner and install the sound card drivers so that the mouse can burn the dvd via the usb cable. Well at least that may help if we had more info.
    What is the device?!!!! What are we mind readers?
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 13:43
  2. Simple USB Comms Problem
    Last Post: - 6th January 2010, 20:17
  3. USB / RS485 communication
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 7th May 2009, 19:36
  4. PIC18f2550 usb communication with a mobile phone
    By TD26 in forum mel PIC BASIC Pro
    Last Post: - 25th February 2008, 19:13
  5. USB Serial Communication Continuous
    By pic-ker in forum USB
    Last Post: - 14th February 2007, 12:27
