TMR1H and TMR1L into a word variable
Results 1 to 3 of 3
    xnihilo's Avatar
    xnihilo Guest
    Default TMR1H and TMR1L into a word variable
    Let's say I want to check the value of the TMR1 in a loop in which I'm polling the state of a pin to create some Timeout check.
    I read in the datasheet that TMR1L is at address $0E and TMR1H is at $0f..
    I guess I can create a WORD variable after making an alias to TMR1L and check the value of the word variable.
    Something like:
    tmr1value VAR WORD
    tmr1value.lowbyte = TMR1L
    then read tmr1value
    Is this right?
    Better to use this
    @TMR1Word = TMR1L
    TMR1Word VAR WORD EXT
    http://www.picbasic.co.uk/forum/showthread.php?t=3891
    xnihilo's Avatar
    xnihilo Guest
    Excellent. Thank you, I will try that.
  1. 16f877A and tmr1 external crystal question
    By comwarrior in forum General
    Last Post: - 13th July 2009, 01:40
  2. pic basic i2c bus does not work
    By tamertokgoz in forum mel PIC BASIC Pro
    Last Post: - 12th June 2008, 23:57
  3. Writing to high/low variable pairs?
    By kevj in forum mel PIC BASIC Pro
    Last Post: - 1st September 2007, 19:00
  4. Timers !
    By n qwerty in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2007, 12:39
  5. Measuring change of frequency with PIC
    By Aussie in forum mel PIC BASIC Pro
    Last Post: - 19th July 2007, 02:47
