Transistor Selection for Switching Relay Coil-with a little bit of info on my "ARSC"
Results 1 to 25 of 25
    Omaha, Nebraska USA
    Quote Originally Posted by rxforspeed View Post
    For some reason, I couldn't get that second link from your other post to open . . .
    Try http://www.st.com/stonline/products/ and then use the second box to do a part number search for ULN2803 or ULN2803A.
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    Oct 2008
    Ashland, KY
    Quote Originally Posted by RussMartin View Post
    That worked, thanks again sir! I see exactly what you mean, too-the more ouputs you're using and/or the higher the current draw through the array equals less overall time the array IC can be used. I don't believe that my program and the current needs of the relays I'm using will be too much for these.
    I will, however, have a back-up-just in case, with the 5V relays (power supply isolated from PIC's) and the 2N7000's. Thanks again for all the help!
    Sincerely,
    -Adam Collins
    Last Post: - 14th June 2016, 08:55
  2. Sleep Mode
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 13th March 2008, 11:31
  3. PICBasic newbie problem
    Last Post: - 12th February 2008, 01:55
  4. Serial Relays
    By tazntex in forum General
    Last Post: - 17th May 2007, 18:42
