While Loops Slow??
Results 1 to 13 of 13
    Just a thought...
    How much faster if any would it be to check one pine and not the whole port?
    If faster then maybe use a shift register into one pin.
    Probably no better.
    Aug 2008
    Well I am still having problems, so I have been doing some testing.
    Using this exact code:
    CMCON = 7								' Disables the Comparitor Pins
    ADCON1 = 15								' Disables the A/D Converter Pins
    TRISF = $F0								' Define Port F(0-3) as LED Outputs
    Define OSC 20							' Sets Oscillator Speed at 20Mhz
    Define BUTTON_PAUSE 100					' Sets Button Debounce time to 100 ms
    Define I2C_SLOW 1						' Sets I2C Speed to 100KHz
    Main_Loop:
    PortF.0 = 0
    PortF.0 = 1
    PortF.1 = 0
    PortF.1 = 1
    PortF.2 = 0
    PortF.2 = 1
    PortF.3 = 0
    PortF.3 = 1
    Goto Main_Loop
    The Clock is dead on at 20MHz as measured on an oscilloscope.
    Each pin takes about 200nS to go low then return high... Which seems on par with the 18F8722 data sheet stating that it take 4 clock cycles to exicute a command.
    I actually measured the old device clock. It is running at 1MHz. Given that the fasted the 18F8722 can run each command, I basically can run 5 commands for each of the old devices clock cycles. Buy looking at my original code a few posts back it looks like I can do what I want to unless the compilier is creating bloated assembly code...
    Jan 2006
    Istanbul
    May be you should try this:
    IF PortA = $0B THEN TOGGLE PortB.0
    WHILE PORTA = $0B  : WEND
    This way, your very fast PIC will wait for your very slow old equipment.
    If you do not wait in "while" loop, then PIC will loop thousand times until your old equipment changes its state.
    There is no way your original code could be 5 instructions or less per loop. Each line of code will create at least 1 instruction. You have 4 lines inside the while, so at least 4 instructions plus two for the while (test and branch) will be executed each loop. For every if statement that is true you will get at least 1 additional instruction if not more.
    So now you need to look at the old equipment and determine how fast you really need to detect changes. Is the original equipment running on a 1 MHz clock or is the output signal yopu want to monitor changing at a 1 MHz rate? If the signal you are looking at is changing at a 1 MHz rate, you will need a faster solution to detect it.
    Tim Barr
    You know, thinking on it more, maybe speed is not an issue. If you are using the PIC to replace a 7 segment display with a dot matrix display, and you are trying to translate 7 segment lines into characters so you can send characters to a dot matrix display, this is something the human eye is looking at and the 7 segment display may not really be changing at a 1 MHz rate. I bet the old design is multiplexing the 7 segment displays at a much lower rate than you think. What you may need to do is detect which 7 segment digit is active, read the data going to that display and then translate it into a character to send to the dot matrix display. Typically that is milliseconds, not nanoseconds that you are dealing with. Unless the 7 segment displays have 7 segment decoders that the processor is writing to. Then you have to capture data when it is clocked into the decoder register. In that case, you could sense the clock edge and then read the data bus.
    Tim Barr
    Hey Frozen001, any luck???
    Tim Barr
    Aug 2008
    Well I boiled it down to the fact that PICBasic makes bloated code when you finally get to the actual number of inctructions it takes to perform certain tasks. My WHILE loops take more instructions than REPEAT:UNTIL loops. I got it working with a lot of tweaking by trying different commands.
  1. 4 Channel Thermostat using PID loops
    By malc-c in forum Code Examples
    Last Post: - 18th March 2013, 10:17
  2. Multi Slow speed PWM and Instant Interrupts
    By DaveC3 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2010, 12:50
  3. Slow code needs a tune up
    Last Post: - 5th January 2010, 15:05
  4. Going Loopy - How do i get my Loops sorted out ???
    By gtvmarty in forum mel PIC BASIC Pro
    Last Post: - 24th September 2009, 05:02
  5. Code Executing Slow
    By Frozen001 in forum mel PIC BASIC Pro
    Last Post: - 5th September 2008, 21:09
