ADC problem
Results 1 to 4 of 4
Thread: ADC problem
    NacNud's Avatar
    NacNud Guest
    Arrow ADC problem
    Hello,
    First I want to say that this is a nice forum finding solutions for PBP.
    Here is my queston about an Analog to digital conversion.
    I want to put an conversion in the variable word_temp_int, but this ain't seem to work. Every result of the AD conversion is 0.
    Using a PIC16F870.
    This code is in my interrupt routine, the routine is 500 ms. The varaiable word_wachttijd_aantal is decreased with every interrupt.
    if (word_wachttijd_aantal == 12) and (byte_status == 1) then
       adcon0.0 = 1                            ' AD converter on
    if (word_wachttijd_aantal == 11) and (byte_status == 1) then
       word_pot_adc = 0                     ' reset value potmeter
       adcon0.2 = 1                         ' start AD conversion
    if (word_wachttijd_aantal < 11) and (byte_status == 1) then
       if adcon0.2 == 0 then                   ' test AD conversion ready
          word_temp_int.highbyte = ADRESH      ' store AD value
          word_temp_int.lowbyte = ADRESL       ' store AD value
          word_pot_adc = word_pot_adc * 9      ' some calculations
          word_pot_adc = word_pot_adc + word_temp_int
          word_pot_adc = word_pot_adc / 10
       adcon0.2 = 1                            ' start new AD conversion
    The AD converter is put on when word_wachttijd_aantal is equal to 12.
    500 ms later the AD converter is started when word_wachttijd_aantal is equal to 11.
    500 ms later the AD converter is stored in word_pot_adc because word_wachttijd_aantal is less than 11 and adscon0.2 is equal to 0 a long time ago.
    After the AD value is stored in word_pot_adc a new AD conversion is started.
    If I put de code untherneath here at the same place it works fine.
    test:
       pause 500                               ' wait 500ms is
    ADC:
       pause 5                                 ' wait 5ms aquisition time
       if adcon0.2 = 1 Then ADC                ' test if AD conversie is ready
       word_pot_adc.highbyte = ADRESH          ' store AD value
       word_pot_adc.lowbyte = ADRESL
       adcon0.0 = 0                            ' AD converter off
    goto test
    what about if you put an PAUSE 50 after starting the analog to digital conversion. This will give the PIC enough time to convert and store it to your var.
    BTW wich PIC are you using ?
    if nothing work, can you post/attach your whole code?
    NacNud's Avatar
    NacNud Guest
    I have found the answer myself. The if statements where more than 4 levels deep. Thx mister_e for your reply.
    kinda, but look a this part of your code really closer
    in clear if you A/D conversion is not ready you begin a new one...
    Simple to modify...
       while ADCON0.2    'wait until AD conversion is ready
              pause 5
       Wend
    IF THEN statement don't use stacks... SO you can use as many level you want... SUBs use stacks
  1. pic12f675 ADC problem
    By radu022003 in forum mel PIC BASIC
    Last Post: - 1st September 2009, 11:13
  2. PIC18F2423, ADC problem
    By mistergh in forum mel PIC BASIC Pro
    Last Post: - 17th March 2009, 02:31
  3. Mutliple ADC problem with PIC16F877
    By andyto in forum mel PIC BASIC Pro
    Last Post: - 3rd October 2007, 18:47
  4. ADC problem with PIC16F917
    By eetech in forum mel PIC BASIC Pro
    Last Post: - 7th March 2007, 22:22
  5. Problem reading multiple ADC ports
    By jswayze in forum mel PIC BASIC Pro
    Last Post: - 4th November 2004, 17:46
