ADC problem
Results 1 to 4 of 4
Thread: ADC problem
Threaded View
    NacNud's Avatar
    NacNud Guest
    Arrow ADC problem
    Hello,
    First I want to say that this is a nice forum finding solutions for PBP.
    Here is my queston about an Analog to digital conversion.
    I want to put an conversion in the variable word_temp_int, but this ain't seem to work. Every result of the AD conversion is 0.
    Using a PIC16F870.
    This code is in my interrupt routine, the routine is 500 ms. The varaiable word_wachttijd_aantal is decreased with every interrupt.
    if (word_wachttijd_aantal == 12) and (byte_status == 1) then
       adcon0.0 = 1                            ' AD converter on
    if (word_wachttijd_aantal == 11) and (byte_status == 1) then
       word_pot_adc = 0                     ' reset value potmeter
       adcon0.2 = 1                         ' start AD conversion
    if (word_wachttijd_aantal < 11) and (byte_status == 1) then
       if adcon0.2 == 0 then                   ' test AD conversion ready
          word_temp_int.highbyte = ADRESH      ' store AD value
          word_temp_int.lowbyte = ADRESL       ' store AD value
          word_pot_adc = word_pot_adc * 9      ' some calculations
          word_pot_adc = word_pot_adc + word_temp_int
          word_pot_adc = word_pot_adc / 10
       adcon0.2 = 1                            ' start new AD conversion
    The AD converter is put on when word_wachttijd_aantal is equal to 12.
    500 ms later the AD converter is started when word_wachttijd_aantal is equal to 11.
    500 ms later the AD converter is stored in word_pot_adc because word_wachttijd_aantal is less than 11 and adscon0.2 is equal to 0 a long time ago.
    After the AD value is stored in word_pot_adc a new AD conversion is started.
    If I put de code untherneath here at the same place it works fine.
    test:
       pause 500                               ' wait 500ms is
    ADC:
       pause 5                                 ' wait 5ms aquisition time
       if adcon0.2 = 1 Then ADC                ' test if AD conversie is ready
       word_pot_adc.highbyte = ADRESH          ' store AD value
       word_pot_adc.lowbyte = ADRESL
       adcon0.0 = 0                            ' AD converter off
    goto test
  1. pic12f675 ADC problem
    By radu022003 in forum mel PIC BASIC
    Last Post: - 1st September 2009, 10:13
  2. PIC18F2423, ADC problem
    By mistergh in forum mel PIC BASIC Pro
    Last Post: - 17th March 2009, 01:31
  3. Mutliple ADC problem with PIC16F877
    By andyto in forum mel PIC BASIC Pro
    Last Post: - 3rd October 2007, 17:47
  4. ADC problem with PIC16F917
    By eetech in forum mel PIC BASIC Pro
    Last Post: - 7th March 2007, 21:22
  5. Problem reading multiple ADC ports
    By jswayze in forum mel PIC BASIC Pro
    Last Post: - 4th November 2004, 16:46
