Reading from External Hex Address...
Results 1 to 5 of 5
Threaded View
  1. #2
    May 2008
    Italy
    You can use three push-buttons. Two for up & down to select the address you want to send out. once you have the wanted address on the LCD then you press the send button. This command SEROUT your address code and immediatly you SERIN to listen the answer that you will direct to the LCD after your maths manipulations.
    I have no idea of how many codes you need to handle, but if they are too many and will not fit in the internal eeprom, than you have the chance to use an external memory chip via I2C.
    Al.
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 22:14
  2. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 14:46
  3. External EEPROM Not getting data (24LC515)
    Last Post: - 22nd March 2005, 13:16
  4. Reading a Hex value from a Modem and showing it as Decimal..
    Last Post: - 16th March 2005, 17:58
  5. 18f452 internal eprom help
    Last Post: - 13th July 2004, 15:50
