PIC16F628A programming help
Results 1 to 18 of 18
    Oct 2008
    It's certainely not better than JDM. Anyways, did you tried other software? From the RCD website, they list IC-Prog, WinPic and PICProg4U. May worth a look to.
    Are you using a USB-to-Serial converter between your PC/Laptop and your programmer?
    no
    me using desktop
    i connect the programmer direct to the serial port
    Well, i don't know what else i could suggest...
    1. Make sure MCLR/VPP pin goes ~13V while trying to program.
    2. try to sit a 0.1 uf on the top of your PIC, between Vdd and Vss pin.
    3. Make sure that your programmer is as per their schematic if you built it yourself.
    Try with other software, some like IC-PROG seems to show some setting suggestions for each programmer type.
    good luck
    I know what I'd suggest...
    Oct 2008
    hi
    I build another programmer
    wen me trying to programme with this new one..
    the same error message is shows
    wat can I do
    http://electronics4everyone.blogspot...rogrammer.html
    the above is my 2nd programmer
    Quote Originally Posted by bentech4u View Post
    hi
    wat can I do
    & ju5 t1nk, wit al d@ $$$ u 5p3nt 0n b1ld1n pr0grmr5, u culdv bawt a PICKIT2 & ~ had aneee problem5
    Oct 2008
    at the time of flashing, I checked the voltage across MCLR and VSS
    around 13 volts is coming
    Oct 2008
    Pickit2...???????
    Oct 2008
    I made another simple programmer
    it shows the same error message
    http://www.circuitdb.com/downloadimg.php?fileID=88
  1. Data Programming Error at 0000
    By cpatnoi in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2009, 04:37
  2. Problems programming
    By Lionheart in forum General
    Last Post: - 7th December 2008, 17:51
  3. Help Pic16f628a
    By gadelhas in forum mel PIC BASIC Pro
    Last Post: - 27th August 2008, 00:22
  4. Replies: 8
    Last Post: - 22nd July 2008, 21:31
  5. Some questions for programming
    By fnovau in forum mel PIC BASIC Pro
    Last Post: - 5th July 2006, 17:04
