Your problem is the internal oscillator. As already suggested in post#4, use a 4 MHz xtal or a resonator also for the pic, and you will see that the serial communication will work.
Al.
Might not be the internal osc though...
As has been pointed out somewhere (don't remember where) before, those internal oscillators aren't as loose as they used to be...unless of course it's an older chip in the first place.
