18f2550 USB OSC Problem
Results 1 to 11 of 11
    Oct 2008
    Thanks for your interest.
    This is what I have done.. So I want to make serial connection
    Now i reduced my code.. Now it's working... but if I use PAUSE 1000 without for.. next, it interrupts USB connection.. But leds blinking right time... I will try now serial connection again..
    Another question : For what do I need DEFINE RESET_ORG 800h and DEFINE INTERRUPT_ORG 808h ?
    define OSC 48
    DEFINE LOADER_USED 1
    I VAR word
    LOW PORTB.0
    HIGH PORTB.1
    USBINIT
    dongu:
    FOR I=1 TO 1000
    usbservice
    pause 1
    NEXT I
    toggle portb.0
    toggle portb.1
    goto dongu
    Yup, USBService work a treat when you take care of it each millisecondes or so. Another route is to use a Timer intterrupt such as in the first USBDemo version.
    EVEN BETTER, look at the following modified version A.K.A post #148 which use Darrel's instant interrupts...
    http://www.picbasic.co.uk/forum/show...&postcount=148
    so now you no longer need to care about USBSERVICE, it will be done automatically... BUT i've NEVER tried with the bootloader firmware installed
    Oct 2008
    Can you tell me or give me the code, how can I add TMR0 interrupt to my project ?
    But I understood after your explenation what this lines mean
    I think Interrupts begins after 808h so when an interrupt occurs it will not jump to bootloaders section .. Can be ?
    have a look at USBDemo, first post, first code, everything should be clear after that.
    http://www.picbasic.co.uk/forum/showthread.php?t=5418
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 14:43
  2. Simple USB Comms Problem
    Last Post: - 6th January 2010, 21:17
  3. 18F2550 MCRL/RE3 problem with USB bootloader Microchip
    By Ronald123 in forum mel PIC BASIC Pro
    Last Post: - 24th September 2007, 11:48
  4. Speed of USB EasyHID and Time problem
    By sjohansson in forum USB
    Last Post: - 18th January 2007, 23:21
  5. 18f2550 'access is denied' USB error?
    By Giulio in forum mel PIC BASIC Pro
    Last Post: - 30th December 2006, 15:29
