help with pwm
Results 1 to 7 of 7
Thread: help with pwm
    Default help with pwm
    can anyone help with code to generate pwm 0f 5ohz from 16f877a
    Thumbs down
    SEARCH Function ...
    Question has already been asked here ...
    it's unlikely you'll be able to produce a real hardware PWm using hardware PWM module (HPWM), you'll need to use a software PWM, easy to build with Timer Interrupts.
    One way to go is to use the following
    http://www.pbpgroup.com/modules/wfse...hp?articleid=6
    May 2007
    Not with a PIC16 or PIC18 you won't. What is needed is a PIC with a 16-bit period register. With any of the 24-bit core devices, you can get below 10Hz easily with 16-bit resolution on the duty cycle.
    I KNOW.. it's just not PBP related
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by babatundeawe View Post
    http://www.essex1.com/people/speer/large.html
    How much is an ohz?
    Default many thanks
    [QUOTE=mister_e;65164]it's unlikely you'll be able to produce a real hardware PWm using hardware PWM module (HPWM), you'll need to use a software PWM, easy to build with Timer Interrupts.
    http://www.pbpgroup.com/modules/wfse...hp?articleid=6[/QUOT
    thanks guys i will sure work on this clues.
  1. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 22:18
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 06:03
  3. PWM: Vernacular/Function (Newbee)
    By TerryN in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2008, 16:58
  4. PWM setting PIC16F887
    By Gevo in forum mel PIC BASIC Pro
    Last Post: - 12th June 2008, 07:24
  5. Tidying Up PWM Routine
    Last Post: - 21st February 2005, 00:26
