Timer1 - frequency measurement
Results 1 to 16 of 16
    Jul 2007
    Looking at this ...pic. I do think PbP has not its place inside the 870 !!!
    125 Khz * 256 = ... 32 Mhz
    What do you mean?
    and the 125khz is that the maximum frequency the 16f870 can capture?
    Timer1 can work with some pretty quick external input clocks. Check the electrical specs
    section TIMER0 AND TIMER1 EXTERNAL CLOCK REQUIREMENTS.
    Look at the specs for T1CKI High Time, T1CKI Low Time, and T1CKI Input Period.
    With a pickup coil tuned to the frequency you're measuring, and the /64 output, it should
    be pretty simple to measure your freq range.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jul 2007
    Hi Bruce,
    I've read that, but i don't totally understand it, thats why i wanted some help in getting started, i no timer1 would do what i need, but i don't no how to control timer1, i've never written a program that uses it.
    May 2008
    Italy
    Visit the given link, schematic and code available.
    http://digilander.libero.it/alfred73/eprojects.htm#1300 Mhz Frequencymeter with prescale
    Al.
    Which part are you having trouble with? I'll be happy to explain it.
    T1CON on the 16F870 only has 6-bits that control the timer. Let me know what you don't understand that's in the data sheet, and I'll do my best to explain it. It would help if you tried a few code examples, and indicated which part you're having trouble with.
    -Bruce
    tech at rentron.com
    Jul 2007
    I don't understand how i work out, what the maximum frequency timer1 could capture from that data
    The datasheet shows T1CKI High Time min is 30nS for asynch mode with a prescaler of 1:1.
    T1CKI Low Time is 30nS. And T1CKI minimum Input Period is 60nS.
    So 1/60nS = the max input clock frequency it could handle. With your max freq at 200MHz
    divided by 64, you should be well below the max clock input limit.
    Look for AN592. Microchip shows an example using an old PIC1C5x with Timer0 that counts
    up to 50MHz.
    -Bruce
    tech at rentron.com
  1. Help with TIMER1 + SLEEP
    By Yodoad in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2009, 16:07
  2. Advice on frequency measurement to 30MHz
    By Andy Wood in forum mel PIC BASIC Pro
    Last Post: - 27th March 2009, 05:23
  3. inaccurate frequency using TMR1 PI18F452
    By nkarpovich in forum mel PIC BASIC Pro
    Last Post: - 14th October 2006, 17:22
  4. frequency measurement
    By big-x in forum General
    Last Post: - 25th November 2005, 01:53
  5. Timer1 and Interupt wierdness
    By mind in forum mel PIC BASIC Pro
    Last Post: - 23rd August 2005, 02:24
