Neon effect
Results 1 to 8 of 8
Thread: Neon effect
    Jul 2007
    Default Neon effect
    pls, can anyone help me to achive a "neon effect" with 6 or 8 SMD led-s and 12F629 or 16F84 in PBP.
    Example is in attach.
    For sequence of lighting individual LED can be used numbers stored in EEPROM instead of random generated.
    Andrej
    Bombay, India
    Yes, are you willing to pay for this?
    Jul 2007
    ...are you willing to pay for this?
    No, no
    I didnt mean to commercialize yours idea.
    Im just hobiest in model railroading with some knowledge of PIC programming, and I want to illuminate my layout.
    I did not mean a complete code, maybe a snippet for effect of one LED.
    Thanks, anyway !
    Andrej
    Bombay, India
    You could use 8 outputs to drive the smd leds. Have a table of bytes to write as the 'effect' you want. Then, sit in a loop doing this
    counter = 0
    loop:
    counter = counter+1
    if counter > tablesize then counter = 0
    read byte from table[counter]
    write byte to the port
    pause for as long as you want
    goto loop
    This should get you started.
    Jerson
    Jul 2007
    I will try some, but how can I randomize a sequence of lighting according a numbers stored in EEPROM and finally light up all LED-s ?
    Andrej
    Bombay, India
    your table could contain the lighting sequence which you want to produce
    example
    00011001 - light 3 leds
    00100101 - light another 3 leds
    11100011 - another pattern
    Do this and fill your table with whatever you want.
    Jerson
  1. Hall Effect flow meter with 16F876
    By revelator in forum mel PIC BASIC Pro
    Last Post: - 10th March 2010, 20:42
  2. PWM and fade effect
    Last Post: - 10th July 2009, 10:58
  3. Hall effect reading
    By ewandeur in forum mel PIC BASIC Pro
    Last Post: - 26th November 2008, 15:49
  4. Cricket Sound Effect
    Last Post: - 15th January 2008, 09:10
  5. hall effect
    By dragons_fire in forum mel PIC BASIC Pro
    Last Post: - 10th April 2007, 15:49
