Could you use a 12F683, vary the duty cycle of the PWM output according to the input voltage, and smooth it?
For the op-amp approach, you might see if the TLC271 would work well enough in a single-ended application.
Russ
N0EVC, xWB6ONT, xWN6ONT
"Easy to use" is easy to say.
