HI2CREAD for 18Fs
Results 1 to 10 of 10
    Sep 2005
    Campbell, CA
    I'm happy that you have that code... Would you care to share, or is it in some 'public' place already?
    Charles Linquist
    Feb 2003
    Sydney, Australia
    I'd also love to see that. Getting my hands dirty with HW I2C isn't quite as much fun as I though it might be...
    bill.
    Hangover, Germany
    Talking
    Hello,
    find attached my code (2 years old and not the best!).
    I have removed the maincode.
    I2C reads in bytes and fills up a buffer I2C_In.
    The maincode generates data in a second buffer I2C_Out.
    The incoming bytes are only single bytes, I don't know if the routine will manage more than 1 data in a message.
    Just read the code and try to understand the statemachine of the I2C-hardware.
    Sep 2005
    Campbell, CA
    Thanks! And fortunately for me - my wife speaks German!
    Charles Linquist
    Mar 2008
    Gerogetown, Texas
    Here is a little program that drives a LCD as a I2C slave
    '*  Notes   : PIC 18F4550                                                  *
    define LOADER_USED 1
    define RESET_ORG 800h
    define INTERRUPT_ORG 808h
    DEFINE OSC 48
    '**** LCD *******************************************************
    'Set LCD Data port
    DEFINE LCD_DREG PORTA
    'Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_DBIT 0
    'Set LCD Register Select port
    DEFINE LCD_RSREG PORTA
    'Set LCD Register Select bit
    DEFINE LCD_RSBIT 4
    'Set LCD Enable port
    DEFINE LCD_EREG PORTA
    'Set LCD Enable bit
    DEFINE LCD_EBIT 5
    'LCD RW Register PORT
    'DEFINE LCD_RWREG PORTB
    'LCD read/write pin bit
    'DEFINE LCD_RWBIT 5
    'Set LCD bus size (4 or 8 bits)
    DEFINE LCD_BITS 4
    'Set number of lines on LCD
    DEFINE LCD_LINES 2
    'Set command delay time in us
    DEFINE LCD_COMMANDUS 2000
    'Set data delay time in us
    DEFINE LCD_DATAUS 50
    ' Initialize ports and directions
    ADCON1 = $F       'port A digital
    CMCON = 7         'PortA Digital
    ' PicBasic Pro I2C slave program
    ' Alias pins
    scl     VAR     PORTB.1         ' I2C clock input
    sda     VAR     PORTB.0         ' I2C data input
    ' Define used register flags
    SSPIF   VAR     PIR1.3          ' SSP (I2C) interrupt flag
    BF      VAR     SSPSTAT.0       ' SSP (I2C) Buffer Full
    R_W     VAR     SSPSTAT.2       ' SSP (I2C) Read/Write
    D_A     VAR     SSPSTAT.5       ' SSP (I2C) Data/Address
    CKP     VAR     SSPCON1.4        ' SSP (I2C) SCK Release Control
    SSPEN   VAR     SSPCON1.5        ' SSP (I2C) Enable
    SSPOV   VAR     SSPCON1.6        ' SSP (I2C) Receive Overflow Indicator
    WCOL    VAR     SSPCON1.7        ' SSP (I2C) Write Collision Detect
    ' Define constants
    I2Caddress CON	$A2				' Make our address 2
    ' Allocate RAM
    result	VAR		BYTE			' ADC result
    datain 	VAR     BYTE			' Data in
    dataout	VAR     BYTE[8]			' Data out array
    readcnt	VAR     BYTE            ' I2C read count
            readcnt = 0				' Zero counter
    lcdout $FE,1,"    I2C LCD"
    lcdout $FE,$C0,"     Ready"
    trisb = %00000000
    portb.0 = 0
    portb.1 = 0
    TRISB = %11111111
    'pause 500
    ' Initialize I2C slave mode
            SSPADD = I2Caddress		' Set our address
            SSPCON2 = $0 			' General call address disabled
            SSPCON1 = $36 			' Set to I2C slave with 7-bit address
    GoTo mainloop 			' Skip over subroutines
    i2cslave:						     ' I2C slave subroutine
    		SSPIF = 0				     ' Clear interrupt flag
            IF R_W = 1 Then goto i2crd   ' Read data from us
            IF BF = 0 Then goto i2cexit  ' Nothing in buffer so exit
            IF D_A = 1 Then goto i2cwr   ' Data for us (not address)
            IF SSPBUF != I2Caddress Then goto i2cexit	' Clear the address from the buffer
            readcnt = 0				' Mark as first read
            GoTo i2cexit
    i2cwr:							' I2C write data to us
            datain = SSPBUF			' Put data into array
            lcdout  datain
            GoTo i2cexit
    i2crd:							' I2C read data from us
            IF D_A = 0 Then
            EndIF
            SSPBUF = dataout[readcnt]	' Get data from array
            CKP = 1                 	' Release SCL line
            readcnt = readcnt + 1   	' Move along read count
            GoTo i2cexit            	' That's it
    i2cexit:
    mainloop:						' Main program loop
            IF SSPIF = 1 Then			' Check for I2C interrupt flag
                    GoSub  i2cslave
            EndIF
            GoTo mainloop           ' Do it all forever
    I think I found this on this forum.
    Oct 2008
    Thanks so much
    Sep 2005
    Campbell, CA
    And thanks from me as well. I'm certain I can get something working now.
    Charles Linquist
  1. HI2CREAD and HI2CWRITE
    By garryp4 in forum PBP Wish List
    Last Post: - 24th October 2008, 11:46
