Effiency calculation
Results 1 to 4 of 4
    Hi, Singh
    You have lots of really inexpensive ( about 20 US$ ) ... Power ( or Energy) meters ( U*I*Pow factor calculating ) on the market : one at the input, one at the output and voilą ...
    I got mine from ELV Electronics in Germany.
    Worth the sensors + developing time ... no ???
    Omaha, Nebraska USA
    Would something like this help you?
    http://www.p3international.com/produ.../P4400-CE.html
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    Jan 2008
    Hi, Singh
    Hi Alain,
    Thanks for your suggestion, but my actual problem is " I'm designing a line conditioning unit using SCR contrl, controled by microcontroller, in this unit I want to display, input voltage, output voltage, output current & system efficiency".
    D.K.Singh
  1. Calculation Problem - value goes to zero after 65
    Last Post: - 12th March 2010, 06:10
  2. how to add the calculation of temperature in my source code
    By slimpeng in forum mel PIC BASIC Pro
    Last Post: - 20th February 2008, 17:31
  3. 32-Bit or 64-Bit calculation
    By selbstdual in forum PBP Wish List
    Last Post: - 12th April 2007, 04:59
  4. Battery Life Calculation???
    By manumenzella in forum mel PIC BASIC Pro
    Last Post: - 24th February 2007, 20:26
  5. Need help with lookup table or direct calculation
    By nverma in forum mel PIC BASIC Pro
    Last Post: - 11th October 2006, 19:27
