PC to EUART on pic 16F688
Results 1 to 11 of 11
    Sep 2008
    Default PC to EUART on pic 16F688
    I'm transmitting 5 bytes of data at a time. Decimal 0,0,1,127,128. The data goes from a UART on a netburner card to the RX pin on a 16F688. About 50% of the time I get a USART Overrun error. In addition, the pic chip sometimes restarts up showing a buffer error.
    I'm using the internal oscillator at 4MHz and running at 2400 baud. Wondering if anyone can identify an issue with my code. The data makes it through most of the time without trouble, but I'm not sending a lot of data and there are seconds between when I send another 5 bytes. Curious if my defines are ok also? The code is taken from the samples list online and modified slightly. The only odd things is I look through the buffer with each byte that is collected and look for the 0,0,1 bytes to be there. Then the next byte will be a steering value and the next a throttle value.
    ' PicBasic Pro program to demonstrate an interrupt-driven
    ' input buffer for Hserin using On Interrupt.
    ' Pin definitions compatible with LAB-X1 and PIC16F877
    DEFINE HSER_RCSTA 90h 'SPEN=0, CREN=0
    DEFINE HSER_TXSTA 20h 'BRGH=0, SYNC=0, TXEN=1
    DEFINE HSER_BAUD 2400
    SPBRG = 25 ' Set baud rate to 2400 for USART
    Include "modedefs.bas"
    RCIF VAR PIR1.5 ' Alias RCIF (USART Receive Interrupt Flag)
    OERR VAR RCSTA.1 ' Alias OERR (USART Overrun Error Flag)
    CREN VAR RCSTA.4 ' Alias CREN (USART Continuous Receive Enable)
    LCD VAR PORTC.1 ' Alias for LCD
    buffer_size CON 32 ' Sets the size of the ring buffer
    buffer VAR BYTE[buffer_size] ' Array variable for holding received characters
    index_in VAR BYTE ' Pointer - next empty location in buffer
    index_out VAR BYTE ' Pointer - location of oldest character in buffer
    bufchar VAR BYTE ' Stores the character retrieved from the buffer
    i VAR BYTE ' loop counter
    col VAR BYTE ' Stores location on LCD for text wrapping
    errflag VAR BYTE ' Holds error flags
    carsteering Var byte ' Car Steering
    carthrottle Var byte ' Car Throttle
    index_in = 0
    index_out = 0
    i = 0
    SEROUT LCD,N9600,[$1b,$2a,$40] 'Set Backlight Brightness
    SEROUT LCD,N9600,[$fe,1] ' Clear Screen
    INTCON = %11000000 ' Enable interrupts
    ON INTERRUPT GoTo serialin ' Declare interrupt handler routine
    PIE1.5 = 1 ' Enable interrupt on USART
    loop: ' Main program starts here - do nothing for now
    display: ' dump the buffer to the LCD
    IF errflag Then error ' Handle error if needed
    IF index_in = index_out Then loop ' loop if nothing in buffer
    GoSub getbuf ' Get a character from buffer
    If (buffer[index_out-4] = 0) then
    if (buffer[index_out-3] = 0) then
    if (buffer[index_out-2] = 1) then
    carsteering = buffer[index_out-1]
    carthrottle = buffer[index_out]
    SEROUT LCD,N9600,["Car=1"]
    SEROUT LCD,N9600,[$fe,$c0] ' Move to beginning of 2nd line
    SEROUT LCD,N9600,["Steering=",#carsteering]
    SEROUT LCD,N9600,[$fe,$94] ' Move to beginning of 3rd line
    SEROUT LCD,N9600,["Throttle=",#carthrottle]
    Endif
    Endif
    GoTo display ' Check for more characters in buffer
    ' Subroutines
    Disable ' Don't check for interrupts in this section
    getbuf: ' move the next character in buffer to bufchar
    index_out = (index_out + 1) ' Increment index_out pointer (0 to 63)
    IF index_out > (buffer_size-1) Then index_out = 0 ' Reset pointer if outside of buffer
    bufchar = buffer[index_out] ' Read buffer location
    error: ' Display error message if buffer has overrun
    SEROUT LCD,N9600,[$fe,$d4] ' Move to beginning of 4th line
    IF errflag.1 Then ' Determine the error
    SEROUT LCD,N9600,["Buffer Overrun"]
    Else
    SEROUT LCD,N9600,["USART Overrun"]
    EndIF
    errflag = 0 ' Reset the error flag
    CREN = 0 ' Disable continuous receive to clear overrun flag
    CREN = 1 ' Enable continuous receive
    GoTo display ' Carry on
    ' Interrupt handler
    serialin: ' Buffer the character received
    IF OERR Then usart_error ' Check for USART errors
    index_in = (index_in + 1) ' Increment index_in pointer (0 to 63)
    IF index_in > (buffer_size-1) Then index_in = 0 'Reset pointer if outside of buffer
    IF index_in = index_out Then buffer_error ' Check for buffer overrun
    HSerin [buffer[index_in]] ' Read USART and store character to next empty location
    IF RCIF Then serialin ' Check for another character while we're here
    Resume ' Return to program
    buffer_error:
    errflag.1 = 1 ' Set the error flag for software
    ' Move pointer back to avoid corrupting the buffer. MIN insures that it ends up within the buffer.
    index_in = (index_in - 1) MIN (buffer_size - 1)
    HSerin [buffer[index_in]] ' Overwrite the last character stored (resets the interrupt flag)
    usart_error:
    errflag.0 = 1 ' Set the error flag for hardware
    Quote Originally Posted by docaberle View Post
    That's most likely your problem right there. Go with external crystal, resonator, oscillator, something...
    But since you said you're having overrun errors, look at the 'F688 datasheet in the OSCTUN section and dial down your internal clock a couple of notches and see what happens.
    Problem is, this will only work at that particular battery voltage, that temperature, that day of the week, when the moon is in that particular phase, etc.etc.etc...
    Just save the trouble and go with an external clock source...
    Could it be something else causing the problem?
    Sure...trying to SEROUT while at the same time receiving serial data in the hardware...bad idea... I'd also be willing to bet if you took all of those SEROUT statement and made it so that each SEROUT statement only did one, two, maybe three characters at a time, you're overrun errors might go away, since it'll give the program/hardware a chance to interrupt and empty out the incoming hardware serial buffer.
    Mar 2005
    Novi Sad, Vojvodina
    "SPBRG = 25 ' Set baud rate to 2400 for USART" ????
    SPBRG = 25 ' Set baud rate to 9600 for USART !!!!!
    Quote Originally Posted by Emil G View Post
    ???? SPBRG = 25 is 9600 at 16 mhz it is 2400 at 4mhz
    Sep 2008
    I haven't tried the crystal yet, but after really simplifying the serout strings, everything works fine. No errors. Then when I added back the code that I took out to simplify things I start having problems again. It's the pauseus commands that give me problems since the pauses are between 1ms and 2ms to control two servos. I can't see any other way of receiving UART data and controlling two servos. I'm trying like crazy to avoid real interrupts and I'd prefer not to have to have another microcontroller. Any suggestions? The deletions are included here. It's the code in the main loop that I added back.
    LED VAR PORTC.2 ' Alias LED
    SERVO1 VAR PORTC.3 ' Alias Servo Port
    SERVO2 VAR PORTC.0 ' Alias Servo Port
    pw VAR WORD ' Pulse Width Variable
    direction Var Byte ' Direction Variable
    carnumber Var Byte ' Car # 1 through 8
    index_in = 0
    index_out = 0
    i = 0
    col = 1
    pw = 1200 ' start servo at extreme left
    direction = 1
    LOW SERVO1
    LOW SERVO2
    ' Main program starts here - blink an LED at 1Hz
    loop: Disable
    HIGH SERVO1
    Pauseus pw
    LOW SERVO1
    HIGH SERVO2
    Pauseus pw
    LOW SERVO2
    Enable
    For i = 0 to 16 ' Delay for 16ms (16*1mS)
    Pause 1 ' Use a short pause within a loop
    Next i ' instead of one long pause
    pause 16 ' set frequency to about 50 Hz
    If direction=0 THEN
    pw = pw - 5
    pw = pw + 5
    if pw > 1800 then direction=0 ' at extreme right, turn CCW. 0 is for left
    if pw < 1200 then direction=1 ' at extreme left, turn CW. 1 is for right
    'SEROUT LCD,N9600,[#bufchar] ' Clear Screen
    'SEROUT LCD,N9600,[#carnumber]
    'SEROUT LCD,N9600,[$fe,$c0] ' Move to beginning of 2nd line
    'SEROUT LCD,N9600,[#carsteering]
    'SEROUT LCD,N9600,[$fe,$94] ' Move to beginning of 3rd line
    'SEROUT LCD,N9600,[#carthrottle]
    'SEROUT LCD,N9600,[$fe,$d4] ' Move to beginning of 4th line
    'SEROUT LCD,N9600,["End of Data Stream"]
    Endif
    Endif
    ' Subroutines
    SEROUT LCD,N9600,["B"]
    Else
    SEROUT LCD,N9600,["U"]
    EndIF
    ' Interrupt handler
    buffer_error:
    usart_error:
    You'd still be better off in the long run using a crystal/resonator...
    Then don't use 1ms-2ms pause's. Give the serial interrupt routine a chance to grab the byte even when there's a pause going on.
    index_in = 0
    index_out = 0
    i = 0
    col = 1
    direction = 1
    LOW SERVO1
    LOW SERVO2
    loop:   Disable
            HIGH SERVO1
            Pauseus (pw>>2
            Pauseus (pw>>2)
            LOW SERVO1
            HIGH SERVO2
            Pauseus (pw>>2
            Pauseus (pw>>2)
            LOW SERVO2
            Enable
            For i = 0 to 1600	' Delay for 16ms (16*1mS)
    	        Pauseus 10   	' Use a short pause within a loop
    '        pause 16                ' set frequency to about 50 Hz
            If direction=0 THEN
                pw = pw - 5
                pw = pw + 5
                  Endif
              Endif
    ' Subroutines
    	Else
    	EndIF
    ' Interrupt handler
    buffer_error:
    usart_error:
    2 things come to mind about these problems, I have experienced with serial backpack using very much the same code. Send your data Open True not driven true and make sure there is a pullup resistor on the Hserin Rx pin so it is in a logic High state at boot.
    Sep 2008
    I don't understand what:
    Pauseus (pw>>2)
    Pauseus (pw>>2)
    does? I can't find anything like this in the manual. Also why is it in there twice for each servo? Do the disable and enable commands negate this anyway if this code is somehow allowing interrupts to happen?
    To Joe S.:
    In other words, my netburner card isn't pulling high properly so I should make it open collector output and put a pull up resistor on the data line and that should correct some problems?
    pw is a variable
    >>2 shifts right two places
    Look at the Math Operators section.
    Pauseus (pw>>2)
    Pauseus (pw>>2)
    I screwed up anyways. They're supposed to be Pauseus (pw >> 1 )
    >> is right-shift, same as divide-by a power of two (>>1=/2, >>2=/4, >>3=/8 and so on). If you right-shift a number by one bit, it's the same as divide-by-2. Same thing for a left-shift, << , multiplies a value by a power of 2.
    I put that in there to split-up the long pause to give the serial port interrupt a chance to kick in.
    At 2400 baud, a byte takes about 4.16ms to arrive. While that is a longer time frame than the pause for the servo, it was just an off-the-head change I thought might help. Might help to split the servo pause into more 'chunks', might not, might help to totally rewrite the code, then again, maybe what you've got is sufficient.
    And DISABLE and ENABLE only disable and enable the PBP interrupt trapping and jumping to the PBP interrupt routine. The interrupts still happen, the bits still get set, but PBP doesn't do anything about them. For instance, if you DISABLE the interrupts, but manually check the individual interrupt flag bits in your code, you can still figure out if an interrupt hit or not.
    To Joe S.:
    I do not know what your netburner is doing. In my use, herserin works better if held high with a resistor and hooked up to ??? which idles high and sends data Open True. Here is a really quick test, pull the serial line from the netburner and hook it to +, boot and after boot hook it back to netburner (quickly), if that solves the problem then my suggestion should work.
  1. Replies: 24
    Last Post: - 2nd October 2017, 12:35
  2. Send data PIC to PC
    By konter in forum Off Topic
    Last Post: - 25th December 2009, 23:04
  3. Replies: 67
    Last Post: - 8th December 2009, 03:27
  4. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 15:46
  5. Replies: 11
    Last Post: - 12th July 2008, 03:36
