Communication with Car central display unit
Results 1 to 3 of 3
    Feb 2007
    Default Communication with Car central display unit
    Hi
    I have a Vauxhall vectra and sinse removing the original stereo which used to display RDS data on the central display in the car, I have been thinking about using the central display for something else for example the inside temperature of the car, ill be using a pic micro with picbasicpro.
    Does anyone know the communication protocol for the display unit?
    and how to connect to it? ie which pins of the connector for the display unit do what?
    Jul 2007
    Bavaria
    Hi Wellyboot,
    have fun with this link:
    http://translate.google.de/translate...hl=de&ie=UTF-8
    Depending on what your car is equipped with, maybe you should try a search for "OPEL MID" for the three-line display or "OPEL TID" for the single line display.
    Ingo
    Feb 2007
    Thanks a lot for the info/link
    I belive my car is the MID display type, it has 2 rows on the display, time and temp at top and date (when radio off at bottom)
    Not too sure how im going to control the MRQ line at the same time as sending I2C data, using the I2CWrite command as it would appear the MRQ line changes state in the middle of the I2C data being transfered.
  1. Hdsp 21xx display
    By Original in forum mel PIC BASIC Pro
    Last Post: - 7th June 2012, 21:07
  2. Replies: 2
    Last Post: - 14th July 2008, 23:11
  3. DS1820 display with 7-seg 4 digits
    By chai98a in forum Code Examples
    Last Post: - 10th April 2008, 14:12
  4. Replies: 14
    Last Post: - 26th September 2007, 06:41
  5. Car Display from old Ericcson A2628
    By ritvarsrizikovs in forum mel PIC BASIC Pro
    Last Post: - 1st March 2006, 11:08
