Warning[202]
Results 1 to 3 of 3
Thread: Warning[202]
    Nov 2007
    Default Warning[202]
    Can someone please tell me what this means?
    Warning[202] ... file location ... 152 : Argument out of range
    This doesn't seem to tell me where the error is. It isn't in line 152, so where is it?
    From the PM.TXT file in your PBP directory
    202 Illegal Character 'Character'
    The assembler doesn't recognize the legal use of the specified character.
    From MPASM
    202 Argument out of range. Least significant bits used.
    Argument did not fit in the allocated space. For example, literals must be 8 bits.
    And if we could see you code it would help.
    Because it is never in line 152.
    Nov 2007
    Smile
    I found it. I had a Byte variable storing the result of a calculation using a Word variable. It worked in my case, because I knew the bounds of the calculation, but hence, the warning. Thanks for responding.
  1. Warning[202]
    By KVLV in forum mel PIC BASIC Pro
    Last Post: - 16th December 2007, 09:30
