Reading a slave USB with a pic
Results 1 to 8 of 8
    May 2005
    Cesena - Italy
    Thanks Skymask for you fast reply !
    I can't choose the communications between PICS...(I like to much the serial communications)
    "SIMPLY" ...I must read data from a USB without a computer!
    An example maybe ...I must read the data outputted form an USB weather station....and reading the data I must speack all values with a sythesis voice..
    Bahhh ..think me crazy!
    Paolo
    May 2007
    There are PIC's that support slave, host as well OTG. However, skimask is correct that you have to look at something other than USB as PBP does not support those PIC's.
    Dec 2005
    I've never looked at it in depth but FTDI has a USB host controller called Viniculum which has UART, SPI & parallel interfaces. It may give you a way to do what you want.They have some sample applications interfacing PICs to USB slave devices. Unfortunately they are in C but they do show that what you want to do is possible with their chip. The chip is about $10 or for about $20 you can get an eval board.
    May 2005
    Cesena - Italy
    This is what I'm looking for!
    Thanks all
    Paolo
    Dec 2005
    Let us know how it works out - along with your PBP code.
    May 2005
    Cesena - Italy
    Order executed!
    Sure I will report all in this same post!
    Paolo
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 14:43
  2. ShiftOut. Using PIC as Slave device.
    By TonyA in forum mel PIC BASIC Pro
    Last Post: - 16th March 2010, 20:10
  3. PIC as USB host
    By dhouston in forum USB
    Last Post: - 27th May 2008, 02:12
  4. USB Pics, ICD2, pic basic pro
    By vacpress in forum USB
    Last Post: - 20th January 2007, 21:50
  5. Need Help with PIC as SPI Slave
    By PICtron in forum Serial
    Last Post: - 16th August 2005, 20:34
