PIC water sensor
Results 1 to 29 of 29
    The light/dark sensor on that page is pretty much what you want.
    Basically the op amp will be a comparator. When the voltage difference between pins 2 and 3 is greater than 1.2 (if I remember) then pin 6 outputs. Single power supply is all that is needed with this setup.
    Jun 2007
    Mansfield, UK
    Ive only just got past the bit about boosted output. Some things are making sense but i think its gonna take a while to sink in properly.
    Would i be right in saying an op amp is very similar (if not the same) as a MAX485 receiver? Now i think about it the MAX485 does have opamp type symbols in the datasheet
    T.Jackson's Avatar
    T.Jackson Guest
    You know I always make dead certain first, before I pull that trigger, on my de-soldering gun to remove MAX485s. Gotta be properly grounded, because they're very static sensitive.
    Jun 2007
    Mansfield, UK
    I hadnt notice that. Im sure the ones ive got must have had pleanty of static with all the things they have been near and they are still working for the moment. One of them even got shorted out when the wires on the biasing resistors accidentally touched but even that still works fine.
    For now im working on breadboards so soldering/desoldering hasnt been a problem
    Quote Originally Posted by The Master View Post
    Maybe...I guess so...
    The 484 is comparing a voltage difference.
    T.Jackson's Avatar
    T.Jackson Guest
    Well you should know Dave, you're the one with the Phd.
    What does your psychoanalysis equate to?
    I would say mine is more "I guess so" while my wifes is "maybe". I used them both so I would not have to be gender specific. Gotta keep the Freudians happy.
    And that is
    MR. Post Hole Digger
    T.Jackson's Avatar
    T.Jackson Guest
    I usually rely predicate logic mostly. This is enough for me, it's all I need.
    Anyway, I'm off to go and clean that gun of mine, gotta a lot of work ahead of me.
    Keeping up with the Freud thing.
    I bet mine is bigger than yours
  1. Need a cheap touch sensor idea.. here it is
    By mister_e in forum Code Examples
    Last Post: - 16th April 2016, 22:42
  2. how to connect ac sensor to PIC ?
    By iugmoh in forum Schematics
    Last Post: - 1st June 2008, 18:35
  3. Water Level Detection using Ultrasonic Sensor
    By Balachandar in forum mel PIC BASIC Pro
    Last Post: - 12th November 2007, 04:59
  4. hot water flow sensor
    By jessey in forum Off Topic
    Last Post: - 24th January 2007, 04:05
