PIC Programmer
Results 1 to 40 of 54
Thread: PIC Programmer
    Oct 2008
    LOL, Hi Dave,
    Yea that's what I was Hopin' to avoid
    I have seen somewhere nice little flat ribbon cables attached to ZIF sockets and /or with nice little test probe ends.
    Now thats why i dont use bread board
    Ive gone for a slightly different approach, ive soldered wires onto the end of the tag strip supplied and put some small crips on which fit tag strips pritty well. Then i have a piece of veroboard with a ZIP in the middle and tag strips runnign down each side so i just move the wires to where i need them for each type of chip.
    Quote Originally Posted by chrisshortys View Post
    Actually, that is exactly what I started to do myself, Gotta order some 20 way sockets.
    I knew that picture would generate a comment or two I was checking out something for one of the posters here at the time. Shows how versatile the PICKIT2 is. ICSP is a piece of cake. And if you are doing a production run and want to use surface mounts all you need to add is some sort of header or connector to the PCB and away you go.
    However you use it, it can not be beat.
    May 2007
    For production, I use spring loaded pins on 1x5 pads on the PCB. Press the button (just below the thumb) and in just a few seconds, the device is programmed and verified.
    I already used some IC clips... works a treat too, you just need to make your own adapter.
    But yeah.. you have to make an adapter for each PIC package.
    Where did you buy the connector ?
    Hi Steve, I have 1 of those for 40 pin.
    May 2007
    Joe, I assume you are referring to the spring loaded pins. I got 10 of them for $6.97 about 2 years ago (I am still using the original 5) from here:
    http://search.digikey.com/scripts/Dk...name=ED8186-ND
    Thank You ! Did you then just stuff them into a connector shell ? Do the long pins protrude through or are these pins just inserted into the PICKit2s connector ?
    May 2007
    The long, skinny end is inserted directly into the PicKIT2. The other end is spring loaded with about 0.1in. of travel.
    If you lay out your board with 1x5 pads (0.1in. spacing, about 0.03in holes) and connect them to VPP/MCLR, PWR, GND, PGD and PGC, the spring loaded end will make good contact. This method will allow you to use any type and size package PIC, whether DIP, SOIC, TSSOP, TQFP, QFN, etc. without needing a different adapter for each one.
  1. Pic Programmer
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 4th October 2008, 06:41
  2. Replies: 6
    Last Post: - 11th November 2007, 21:14
  3. New PIC Programmer
    By DynamoBen in forum Off Topic
    Last Post: - 6th February 2007, 23:23
  4. Serial Pic to Pic using HSER
  5. PIC Programmer & Prototype Board
    By Sparky in forum mel PIC BASIC Pro
    Last Post: - 16th October 2003, 05:58
