revolution counter
Results 1 to 30 of 30
    Sep 2006
    I just want to count the revolution, so even if the trip point is not on the 'dot' it do not matter. What matters here is that I want to be able to calculate the transitions from black to white and white to black. After four transistions I get a revolution .
    The problem in my program is that it is not showing anything on the LCD.
    ken
    Sep 2006
    crap.. I forgot to define my ADC:
    Define ADC_BITS 8 ' Set number of bits in result
    ken
    Quote Originally Posted by lerameur View Post
    ken
    So it is working now???
    Sep 2006
    I dont know if it works, I m at work now, I will see when I get home tonight
    skimask, what do you mean by tripping?
    :is this it...
    ADCON0.2 = 1 'Start Conversion
    ADCIN 1, Output_Pot 'analog pin 1 (RA1) get the 8 bit result
    Ok, I see there's 2 places where I could be 'tripping' !
    1st tripping - by that I mean the point where the ADCIN routine distinguishes between the light and dark area of the disc.
    2nd tripping - Do you see this phrase anywhere in the manual?
    I.E. YOU don't need to start the A/D conversion, ADCIN does that for you.
    Right, but if it's not tripping in the first place, you won't get any counts in the last place...
    And the ADC, yes, that's part of it. The other part is 'starting' the ADC itself.
    Or is this the problem
    DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits) '4 therefore put wire at 4, 5, 6 and 7 of LCD
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Counter not counting !!!
    Last Post: - 20th February 2009, 23:15
  3. Replies: 42
    Last Post: - 14th January 2008, 12:38
  4. 20 Digit Virtual LED Counter
    Last Post: - 19th November 2007, 06:02
  5. Microcontroller with 2 way paging application problem
