revolution counter
Results 1 to 30 of 30
    Sep 2006
    Default revolution counter
    I want to use the COunter command to count the number of revolution I make on a pulley. The speed is variable, therefore I do not know how count will work. Also the counte command requires a period of time, like 1 second in the manual, but I do not want this, s the wheel might be turning for 5 minutes or longer.
    How should I go about calculating the revolution?
    I have black and white wheel encoder, with a sensor reading the analog output to digital.
    ken
    What else will be going on at the same time? Any idea how many times the wheel will turn and how fast?
    May 2008
    Italy
    You must also tell us how many pulses per turn will generate your encoder.
    Sep 2006
    I am making a coiling machine and will be passing the wiring into a small pulley. The pulley will have four sections, two white and two black. The sensor will be reading the encoder , there will be small led lighting the encoder from behind.
    Therefore the speed I do not know, and it is not important, it will be going in one direction. I will be counting four changes for one revolution.
    Here is a program I just wrote, have not tried it yet,
    'Get initil value
    ADCON0.2 = 1 'Start Conversion
    ADCIN 1, OldOutput_Pot 'analog pin 1 (RA1) get the 8 bit result
    pause 50
    if OldOutput_Pot > 127 then
    OldOutput_Pot =1
    if OldOutput_Pot < 128 then
    OldOutput_Pot =0
    Mainloop:
    ADCIN 1, Output_Pot 'analog pin 1 (RA1) get the 8 bit result
    pause 50
    'Calculate the distance
    if Output_Pot > 127 then
    Output_Pot =1
    if Output_Pot < 128 then
    Output_Pot =0
    if OldOutput_Pot == Output_Pot then
    goto Mainloop
    if OldOutput_Pot != Output_Pot then
    counter = counter +1 'If oldOutput_pot is different then Output_pot
    OldOutput_Pot = Output_Pot
    if counter =4 then
    Revolution = Revolution + 1
    counter =0
    lcdout $FE,1, "Counter:",dec counter
    lcdout $FE,$C0, "Revolution:",dec Revolution
    pause 150
    GOTO Mainloop
    Bombay, India
    Ken
    What kind of encoder are you using here? Usually an encoder would give out digital pulses. But, you seem to be using the ADC to decode it. I would suggest that you look at the possibility of counting the pulses via an interrupt. This will keep your mainline code free for other tasks. Darrell Taylor has some nice code that can kickstart you in that direction. Just search for it on this site.
    Jerson
    Sep 2006
    My program is not outputting anything, I think it is a initilizing problem but I do not know what:
    I am posting the header:
    can some one help me:
    ' Internal Oscillation program
    ' A/D testing -RA.1
    ' LCD
    '// Define section //
    INCLUDE "modedefs.bas"
    @ DEVICE pic16F88 MCLR_ON, INTRC_OSC, WDT_ON, LVP_OFF, BOD_OFF, PWRT_ON, PROTECT_OFF, CCPMX_ON
    OSCCON=$60 ' use internal 4MHZ osc
    ANSEL = %01000010 ' set AN1 (RA1) as analog, others to digital
    ADCON1 = %00000000 ' Left justified results in 8 bits
    ADCON0 = %10001001 ' Configure and turn on A/D Module
    CMCON = 7 ' Disable analog comparator
    '// LCD configuration //
    DEFINE LCD_DREG PORTB ' Set LCD Data port
    DEFINE LCD_DBIT 4 ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
    DEFINE LCD_RSBIT 1 ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB ' Set LCD Enable port
    DEFINE LCD_EBIT 0 ' Set LCD Enable bit
    DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits) '4 therefore put wire at 4, 5, 6 and 7 of LCD
    DEFINE LCD_LINES 2 ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2500
    DEFINE LCD_DATAUS 250
    DEFINE CHAR_PACING 2000
    pause 2000
    TRISB = %00000000 ' Set PORTB to all output
    TRISA = %11111111 ' Set PORTA to all input
    '// Variable Declaration and initialization //
    Output_Pot var byte
    OldOutput_Pot var byte
    Revolution var word
    counter var byte
    revolution = 0
    Output_Pot = 0
    OldOutput_Pot = 0
    counter = 0
    'Get initil value
    pause 50
    OldOutput_Pot =1
    OldOutput_Pot =0
    Mainloop:
    Sep 2006
    Jerson,
    this is very simple encoder. I have light to voltage chip, reading the encoder, the encoder is divided into 4 sections, 2 white and two black, read black show ADC below 127 and white ADC above 127.
    ken
    Quote Originally Posted by lerameur View Post
    Jerson,
    ken
    So black is 0 volts and white is 5 volts?
    That's a SOLAR CELL!
    I get the feeling you might end up making a small program just to test the ability of your sensor to read the black/white patches in the first place rather than assuming your sensor/PIC will read everything the way you hope it will. Something like this:
    ........setup.........
    ledout var port...some port here
    main: adcon0.2=1 'Start Conversion
    waitonadc: if adcon0.2 = 1 then waitonadc
    oldoutput_pot = adresh *256 + adresl
    if oldoutput_pot > 127 then
         ledout = 1
         ledout = 0
    Change the value 127 above to find a 'trip point' for the counter itself.
    See what happens with that. If that works for you, then you should be all set.
    (Also, you may want to check the manual for your use of the ADCIN command)
    Wink
    Not compulsory ...
    OPB 608/704 / CNY 70 i.e. are reflective Opto-couplers ...
    Sep 2006
    I just want to count the revolution, so even if the trip point is not on the 'dot' it do not matter. What matters here is that I want to be able to calculate the transitions from black to white and white to black. After four transistions I get a revolution .
    The problem in my program is that it is not showing anything on the LCD.
    ken
    Sep 2006
    crap.. I forgot to define my ADC:
    Define ADC_BITS 8 ' Set number of bits in result
    ken
    Right, but if it's not tripping in the first place, you won't get any counts in the last place...
    And the ADC, yes, that's part of it. The other part is 'starting' the ADC itself.
    ken
    So it is working now???
    Sep 2006
    I dont know if it works, I m at work now, I will see when I get home tonight
    skimask, what do you mean by tripping?
    :is this it...
    Or is this the problem
    Ok, I see there's 2 places where I could be 'tripping' !
    1st tripping - by that I mean the point where the ADCIN routine distinguishes between the light and dark area of the disc.
    2nd tripping - Do you see this phrase anywhere in the manual?
    I.E. YOU don't need to start the A/D conversion, ADCIN does that for you.
    Bombay, India
    Jerson,
    ken
    Precisely. Depending on the way you've wired the sensor, you could see a logic 1 for black or a logic 0 for black. You can just read the digital input after configuring the pins tris register for input mode. Easier than reading the ADC and all its associated overhead. This overhead would eventually cause you to lose counts. I will still prod you into looking at the interrupt option.
    What you've done will work, but at speeds relatively slower than the speed at which you read the ADC.
    A simple routine could have an interrupt set up possibly on RB0. And the interrupt code would do something as simple as this
    CounterISR:
         dummyread = PortB      ' clear the cause of the interrupt
         Counter = Counter+1
         return                        ' from interrupt
    This code will ensure that you catch each and every pulse that comes its way irrespective of the Pauses in your mainline code.
    This code is just a guide, please dont hold me to it.
    JF
    Sep 2006
    OOo I get the digital part now, no need for ADC.
    I have never used interrupt, can you explain the code snippet you provided above?
    should this work?
    Mainloop:
    Output_Pot = PortB.3
    goto Mainloop
    if counter =4 then
    counter =0
    pause 150
    GOTO Mainloop
    ken
    Sep 2006
    still nothing showing on the lcd...
    k
    Well, then get rid of the digital inputs and make sure the LCD is working in the first place...
    And besides, in the beginning of the program, OldOutput_Pot = 0 and Output_Pot = 0 therefore, they're both equal and Mainloop keeps executing! Unless you've preset one or the other to a different value...
    Sep 2006
    I got the circuit working now without the ADC, thats the one I will use.
    BUT,I also tried the ADC, it only works in 10 bit mode when I try the 8 bit mode, nothing appears on the LCD. Here the progrm, but before here is the two lines I changed for the 8 bit mode:
    ADCON1 = %10000010
    why is this happening?
    INCLUDE "modedefs.bas" 'Includes supoprt for PicBasic language
    @ DEVICE pic16F88, INTRC_OSC, CCPMX_ON
    ANSEL = 0
    CMCON = 7 ' Turn OFF the comparators so pins can be used as digital I/O-pins
    ADCON1 = %00000010 ' Analog to digital configuration register (ADCON)
    ' Set PORTA to digital
    ' Define ADCIN parameters
    Define ADC_BITS 10 ' Set number of bits in result
    ADCON1 = %10000010 ' Analog to digital configuration register (ADCON)
    '// PIN configuration //
    TRISA = %11100111 ' Set PORTA to all input
    TRISB = %00001100 ' Set PORTB to all output
    PortA = 0
    Output_Pot var byte
    Revolution var word
    counter var byte
    revolution = 0
    Output_Pot = 0
    OldOutput_Pot = 0
    counter = 0
    'Get initial value
    'ADCON0.2 = 1 'Start Conversion
    pause 50
    if OldOutput_Pot > 512 then
    OldOutput_Pot =1
    OldOutput_Pot =0
    Mainloop:
    pause 50
    if Output_Pot > 512 then
    Output_Pot =1
    Output_Pot =0
    goto Mainloop
    if counter =4 then
    counter =0
    pause 150
    GOTO Mainloop
    Did you set it for left justify or right justify? Makes a difference...
    Sep 2006
    it is in the code above:
    with this it works:
    ADCON1 = %00000010
    but not:
    ADCON1 = %10000010
    Right, with one you're putting the 10 bit value (justified left) into a byte, with the other, you're putting the 10 bit value (justified right) into a byte, trying to stuff 10 bits into a spot for 8 bits.
    So, with one, you get the lower 8 bits of the 10 bits, with the other you get the upper 8 bits of the 10 bits.
    Which one is it? That's for you to figure out....(hint: if you use a word variable for reading, you'll figure it out quickly if you also use the LCD to display that value)
    Sep 2006
    I am using the same config as the sample program on melabs:
    http://www.melabs.com/resources/samples/pbp/adcin8.bas
    as you can see mine is not working.
    k
    k
    Except that they're using 8 bits and a byte, and you tried using 10 bits and a byte.
    (hint: see the hint above about the hint in post #25)
    Sep 2006
    oups, ok i was sleepy last night,
    thanks for your help
    ken
    ken
    All good then?
    Sep 2006
    Yep its good,
    I am just working on reset, so many options, I just want to put zero my values in a push of a button, I think I will just use a pin low pin high, and a loop in my program that verifies this pin.
    I read about power on reset, but I never used it and it is unclear in the documentation I read so far.
    k
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. Counter not counting !!!
    Last Post: - 20th February 2009, 22:15
  3. Replies: 42
    Last Post: - 14th January 2008, 11:38
  4. 20 Digit Virtual LED Counter
    Last Post: - 19th November 2007, 05:02
  5. Microcontroller with 2 way paging application problem
