Timing scheme
Results 1 to 9 of 9
Thread: Timing scheme
    May 2008
    Italy
    I can suggest the following approch:
    Read cycle and ontime word variables
    Compare the the two variables and adjust ontime to cycle if ontime is greater then cycle
    IF ONTIME>CYCLE THEN ONTIME=CYCLE
    If you don't want offtime=0 then you can add the proper offset
    IF ONTIME>=CYCLE THEN ONTIME=(CYCLE-OFFSET)
    Set high output pin
    loop for for the cycle delay and check ontime
    when loop reach ontime value set low output pin
    continue the loop till you reach the cycle time.
    Ontime will be adjustable and always within cycle time
    Al.
  1. 12F683 serout timing
    By Hobie Cat in forum mel PIC BASIC Pro
    Last Post: - 21st December 2009, 17:57
  2. 18F2550 timing
    By sstt1976 in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2008, 01:30
  3. PIC 12c509 - No External timing components
    By stay_aliveuk in forum mel PIC BASIC Pro
    Last Post: - 8th September 2006, 18:20
  4. Questions on timing
    Last Post: - 6th July 2006, 23:38
  5. HSEROUT buffering and timing - 16F88
    By picster in forum mel PIC BASIC Pro
    Last Post: - 5th March 2006, 18:52
