PIC16F877A not working again :(
Results 1 to 25 of 25
    What are you doing with the analog settings or pins.?
    Jun 2007
    Mansfield, UK
    Im not using any analogue. The datasheet says analogue is disabled if ADCON1.0 is 0. It also says that its 0 by default.
    I seem to remember these outputs working before by they arnt doing now. Ive not added any code that changes the state of those pins anywhere except the 1 line
    Try adding this to the start of your code.
    ADCON1=7
    CMCON=7
    Jun 2007
    Mansfield, UK
    That worked Now ive just gotta read the datasheet and find out why
    Thanx
    Quote Originally Posted by The Master View Post
    Thanx
    ADCON0.0 is the start/stop bit of ADCON0.
    ADCON1 is where the pins are controlled. There is a table in the ADCON1 section.
    Comparators are similar.
    This also helps.
    Have Fun
    Jun 2007
    Mansfield, UK
    Im sure ive been pointed to that thread before. I knew about the problem but i thought the settings i had would stop it. Aparently not. I must have misread the datasheet and completely overlooked CMCON.
    I should probably read the whole datasheet when using a PIC. The only problem is that by about page 50 i cant remember what was on page 1. There are a few PICs (including the 16F877A) which seem to cover just about everything i do so hopefully if i just concentrate on these few ill get to know them better.
    It just takes a little time. You are doing fine.
    I only have a dozen or so chips that I use and many of them I do not use all of the features.
    Still learning myself.
  1. PIC16F877A PORTA.2 not working
    Last Post: - 10th October 2009, 18:16
  2. PIC16F877A analog problem
    By DeViLa_Q8 in forum mel PIC BASIC
    Last Post: - 30th July 2009, 20:19
  3. PIC16F877A for application in mobile robot...
    By mcbeasleyjr in forum mel PIC BASIC Pro
    Last Post: - 30th January 2009, 14:47
  4. PIC16F877A not working
    By The Master in forum General
    Last Post: - 16th November 2007, 11:32
  5. communicating pic18f452 with pic16f877a
    By tamersoss in forum mel PIC BASIC Pro
    Last Post: - 13th July 2007, 19:54
