Originally Posted by
docaberle
To Joe S.:
In other words, my netburner card isn't pulling high properly so I should make it open collector output and put a pull up resistor on the data line and that should correct some problems?
I do not know what your netburner is doing. In my use, herserin works better if held high with a resistor and hooked up to ??? which idles high and sends data Open True. Here is a really quick test, pull the serial line from the netburner and hook it to +, boot and after boot hook it back to netburner (quickly), if that solves the problem then my suggestion should work.
