Detect 240V with a PIC
Results 1 to 40 of 49
    He is talking about this
    Jun 2007
    Mansfield, UK
    Ahh, I see. I thought i clicked that link earlier but i must have only clicked the one in the text. That string of LEDs does look incredibly usefull! :P
    Quote Originally Posted by The Master View Post
    Maybe that's why they need the boost-drive...to overcome the reverse voltage...
    Heck, for all I know, those are actually LEZDs...Light Emitting Zener Diodes
    Dec 2005
    Attachment 2922
    Which has absolutely nothing to do with the topic nor with the article I cited.
    You're right. Sorry.
    On my screen, after opening the PDF, the LED booster came up first. I had to scroll UP to see the voltage monitor circuit.
    Jun 2007
    Mansfield, UK
    Im going to get components to try both methods just incase one fails. How do i work out the wattage i need for the 10M resistor method? I can use the maths from that LED page to work it out for the opto but i dont know about the PIC. I assume the PIC counts as some kind of load but only a small one
    Dec 2005
    240 (E) / 10000000 (R) = 0.000024 (I)
    0.000024 * 0.000024 = 0.000000000576 (I squared)
    0.000000000576 * 10000000 = 0.00576 watts (I squared * R)
    or
    240 * 0.000024 = 0.00576 watts (I * E)
    The clamping diodes will conduct when the voltage is > Vdd (+ diode drop) and when the voltage is < Vss (- diode drop) so, in essence, you have the resistor in series with a diode with 240V applied. The above calculations have ignored the forward voltage drop of the diodes as that's insignificant in comparison to 240V.
    Jun 2007
    Mansfield, UK
    Ive just realised that skimask has already given me the formula for that.
    E = IR, P = EI, therefore P = IIR
    I should have realised but i was thinking of the formulas on the LED page. They also use ohms law so it must be the same kind of thing but as i understand it they work out the wattage based on the current required by the LEDs.
    Im gonna read through all 3 ways of doing it again and see if i can understand exactly whats happening in all of them. I can see that the one you just gave me and the one skimask gave me are practically the same just written a little different.
    I did? Oh boy...shouldn't have done that... Well, the damage is done... Pass it along when you get the chance
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 11:00
  2. Detecting 240V with a PIC (Part2)
    Last Post: - 18th March 2009, 20:10
  3. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 22:01
  4. Serial Pic to Pic using HSER
  5. pic detect amperage
    By jetpr in forum mel PIC BASIC Pro
    Last Post: - 11th February 2005, 06:02
