GLCD are plain easy to work with if you want to spend some time on. There's plenty ressource in PBP, ASm and other languages. Maybe i should sale a GLCD pack myself?
As soon as I recover all encrypted data on my main machine... stupid me... short story.. i've made something to encrypt data on my hard drive and it require a USB dongle to unlock it.. which I lost when... you know the story... but... deuh ++idiot, source code for that freaking dongle/encryption method was on that machine
I remember most part of it... but.. tehe.. not enough yet!
Anyways, don't worry, there will be no need for ANY extra hardware or dedicated ICs/built-in solution. copy/paste, INCLUDE and that's it. At least yet, i have some other solution in mind... which would be FAR easier...
I'm taking orders on mine.![]()
http://www.picbasic.co.uk/forum/showthread.php?t=9807
IC Swordfish's based i guess
Not cost effective to me![]()
No, it is mine. I will also be doing a 192x64 and a 240x128 with similar features. Its a complete system requiring just a single port pin. It can be used with low pin count devices. The 128x64 GLCD is priced very competitively compared to other 4x20 serial character LCDs.
They were looking at carrying it so I did a demo for them. Here is a view of the back of the unit.
and some sample code (for Stamp - should be similar for PBP):
Code:SEROUT 1, 396, [85] ' Auto Connect to display at 9600 Baud ' Can be up to 256,000 Baud SEROUT 1, 396, [186] ' Clears the screen SEROUT 1, 396, [188,10,20] ' Position cursor at x10, y20 for text display SEROUT 1, 396, ["Hello World",0] ' Print "Hello World", 0 terminates string SEROUT 1, 396, [255,3,63,31,25,255] ' Draw a circle at x63, y31 ' Radius of circle is 25 pixels ' 255 at beginning and end signifies graphics ' "3" is for circle SEROUT 1, 396, [255,2,20,10,100,50,255] ' Draw a rectangle from x20,y10 to x100,y50 ' "2" is for rectangle SEROUT 1, 396, [255,4,30,0,30,60,255] ' Draw a vertical line from x30,y0 to x30,y60 ' "4" is for line SEROUT 1, 396, [170,185] ' Set brightness level to 185 (from 0-255) ' "170" is command to set backlight brightness ' Value stored in EEPROM
Good idea-I'd pay for the necessary .inc files and whatever else is needed if this would support mikroElektronika's 128x64 GLCD. I'm pretty sure it's a KS0108 or compatable type controller...
Would you be providing some sample source code or examples to paying customers?
What PBP commands would be used to print both fonts (normal and custom) and bitmaps to the screen? "LCDOUT" for normal text, with librarys to "INCLUDE" for pre-drawn bitmaps or "SEROUT mode,(Xpos),(Ypos),(bit)" (or something similar) to add a new bitmap directly in the code? What about plans for touch screen features/examples?
BTW-I hope you can recover your data without too many problems and headaches. Please keep us updated on this; I'm very interested!
Sincerely,
-Adam Collins
Once i have it completed, recovered, i'll do an announcement somewhere here.
This is something really easy to use, couples of macros, DEFINES and that's it. Still working on the recovery thingy though. Oh well, i'll probably redo the whole thing from scratch...
Yes i also have touch-screen interfaces. Those GLCD are really neat, and quite cheap. I got mine from Circuit-Ed. Warren now have RGB backlight model as well... and OH, much neater, no longer need to mess with that tiny flat cable... have a look at the following..
http://www.circuit-ed.com/128x64-Tou...ht-P168C8.aspx
Hi, Steve
I think I've already sent you something really close to the "Made in USA GLCD Controller" ... may be with the PC program "That goes well" ... running @ ...9600 bds too.
Lol !
Maybe... who knows... anyways seems my last trauma removed many traces & "Souvenirs" in my virtual memory![]()
There's also some very useful information on touch screens there as well. Thanks for the link. I'll keep my eyes peeled for your pack...
BTW-did you notice the EasyPIC5 in the video on that page? I thought that unit looked like the mE GLCD I got with my EasyPIC5 (with a different touch screen connector, of course), then I noticed the vid. They both must have the same supplier...
-Adam Collins
Both GLCD use the same controller, same touchscreen, same, same ,same, this one just have everything on the same edge connector + RGB backlight.
