PIC16F84A Tachometer LED routine
Results 1 to 21 of 21
    Great! I'm looking forward to see them!
    Oct 2008
    Denmark
    Default Source for the project
    '*  Name    : RPM.BAS                                           *
    '*  Author  : Christian Lerche                                  *
    '*  Notice  : Copyright (c) 2009 DSB El-teknik                  *
    '*  Date    : 28-05-2009                                        *
    '*  Notes   : PIC16F913, Boden Off, WDT off, PWR off            *
    ' Includes
    ' Defines-----------------------------------------------------------------------
        Define  osc 10                          ' Define oscillator XT 10 MHz
        DEFINE  ADC_BITS 10                     ' Define A/D Converter 10 bit
        DEFINE  ADC_CLOCK 3                     ' Define ADC clock source
        DEFINE  ADC_SAMPLEUS 50                 ' Wait 50 µS before convert to digi
    ' INPUT / OUTPUT----------------------------------------------------------------
        TRISA = 0                               ' PORTA is output
        TRISA.5 = 1                             ' PORTA.5 is input
        TRISB = 1                               ' PORTB is input
        TRISC = 0                               ' PORTC is Output
        TRISB.0 = 1                             ' B0 / Int is count input
        ADCON0 = %10010001                      ' ADC On, right justified
        ADCON1 = 0                              ' ADC Freq = 625KHz
        ASM                                     ; Insert ASM
        BANKSEL LCDCON                          ; LCD Configuration
        CLRF    LCDCON                          ; Turn off LCD Driver
        ENDASM                                  ; End of ASM
    ' Variables and constants-------------------------------------------------------
        W1  VAR WORD                            ' W1 is 16 bit variable
        W2  var word                            ' W2 is 16 bit variable
        W3  var word                            ' W3 is 16 bit variable
        B0  var byte                            ' B0 is 8 bit variable
    ' Main program------------------------------------------------------------------
        ADCIN 4, W2                             ' Read Freq-to-voltage device
        W3 = W2 * 9774                          ' 9999 / 1023 = 9.774
        W1 = DIV32 1000                         ' Put the result in W1
        GOSUB GETNUM                            ' Show RPM
        Goto Main                               ' Do this forever
        END                                     ' For the compilers sake
    ' Subroutines-------------------------------------------------------------------
    GETNUM:
        IF W1 >= 1000   THEN display4
        IF W1 >= 100    THEN display3
        IF W1 >= 10     THEN display2
        IF W1 >= 0      THEN display1
    display4:
        B0 = W1 / 1000	                        ' Find number of thousands
    	W1 = W1 // 1000	                        ' Remove thousands from W1
        Lookup B0,[$3F,$06,$5B,$4F,$66,$6D,$7D,$07,$7F,$67],B0
        PORTC = B0      	                    ' Send segments to LED
    	PORTA = $01     	                    ' Turn on fourth digit
    	Pause 1		                            ' Leave it on 1 ms
    	PORTA = $00	                            ' Turn off digit to prevent ghosting
    display3:
    	B0 = W1 / 100	                        ' Find number of hundreds
    	W1 = W1 // 100	                        ' Remove hundreds from W1
    	PORTA = $02	                            ' Turn on third digit
    display2
    	B0 = W1 / 10	                        ' Find number of tens
    	W1 = W1 // 10	                        ' Remove tens from W1
    	PORTA = $04  	                        ' Turn on second digit
    display1
    	B0 = W1		                            ' Get number of ones
    	PORTA = $08     	                    ' Turn on first digit
        RETURN                                  ' Return to caller!
    Here's the code for the project. I've made it, so it doesn't show the zeroes before the actual RPM.
    I hope some of you can use it. Later I'll post the schematic for F/V converter
    ** EDIT **
    Here's the schematic for the F/V Converter. For the 8V source, i use a small regulator, so that the car can run between 12 and 13.8 V at the battery. Depending on the source to the converter, the potentiometer is turned, until satisfied. Mine will run of the 12V to the ignition coil, so that i have 4 pulses for one revolution of the engine.
    Depending on your choice of pulses, you may use a Frequency generator, at square-wave, and if your car pulses 4 times per revolution, then adjust it, until you get 5V out, at 4*166.66.
    If the car pulses once per revolution, set your frequency generator to 166.66 (mine was digital), and adjust the potentiometer until 5V is reached.
    You've now succesfully made a digital tachometer, that updates faster than the code could ever do, by it self.
    Good luck, and have fun all of you!
    / Lerche
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  3. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 09:42
  4. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 21:19
  5. LCD will not start
