Hi, Santa ( de bois )
1) Just the usual gag with PORTA.4 ...
Did you place an external pullup resistor or something to drive the pin to HIGH state ???
2) I note 10 Mhz need a HS Osc ... ( but generally works with XT !!! )
3)you'd better tryCode:MAIN1: PULSIN PORTA.4,0,W1 ' Measure pulse-width in 4µS resolution GOTO MAIN
Code:MAIN1: RCTIME PORTA.4,0,W1 ' Measure pulse-width in 4µS resolution GOTO MAIN
4) your Mathematics are really bad for INTEGERS using ...
you'd much better use DIV32 ...
W1 = W1 * 4 ' Convert µS to mS
W1 = (60000 / W1) ' Revs in 60 mS
W1 = W1 * 1000 ' Revs in 60 sec
That's the first hits ...
